Question about HP LaserJet 1022 Printer
Printer is on but not taken paper - HP LaserJet 1022 Printer
    Problem Solver:
  • 6 Answers
Pls check fuser & paper pick up roller in the upper side of the tray
Posted on Sep 17, 2010
I have a cannon ir3300i printer is not taken print..computer says out of paper printing..but paper is available in printing..how to resolve this query mail id internetstation2012@gmail.com
try turning off both devices - start you computer first, then start your printer and see if that fixes your issue. if not try again this time leaving out the plug that connects the computer to the printer and then when the computer is turned on turn on the printer then plug it into the computer
Aug 08, 2012 | Canon (6981A002AA) for imagerunner 2200,...
My printer (HP PSC 1350) says there is a paper jam but I have taken the paper out, taken the back off and there is no paper jam. Is there a way to reset it or something?
hi
unplug the printer from power source
open the upper cover
move the CR cartridge carfully at the right position look inside is there any broken pices
Oct 27, 2010 | HP PSC 1350 All-In-One Thermal Printer
I have a new Pixma printer. I got some paper jammed in the printer. After I removed the paper and pressed OK, I still get the error message "Rear cover The paper is jammed. Clear the paper and press...
Make sure all the paper bits are taken off , now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 29, 2010 | Canon Office Equipment & Supplies
My Canon MF4010 printer shows "paper jam" even i have already removed paper
the paper jam could have caused errors so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Sep 28, 2010 | Office Equipment & Supplies
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Printer doesnt print in the right format, even the set up is right. Photo paper just taken from Printer in Landscape format, not in Portrait
check for dirver setting for paper selected and application setting for paper should be same and try with the costum paper size for the same
select small paper and check printing
Nov 08, 2009 | Epson Stylus Photo R320 InkJet Printer
Paper jamed in front roller where paper is taken from
It sounds like your paper pickup roller is worn down and can't grip the paper to pick it up. This roller is located on the bottom of the printer. Pull the paper tray all the way out and turn the printer over and you can see it as seen in the attached picture.
This roller comes in a kit along with the separation pad and the charge roller. When you replace one its best to replace them all. The roller kit is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Oct 17, 2009 | HP LaserJet 1320n Printer
My printer is saying there is a paper trapped
A little help here, please.
First, what type of printer are you usiing? Second, you must follow the entire paper path and make that there are no torn corners stuck in the path anywhere.
If there are none, then it is possible that one of the paper senses are jammed out of position.
May 09, 2009 | Lexmark Office Equipment & Supplies
My photo paper is loaded, but I have tried for an hour and it pulls in the blue tray, pushes it back out and says to load photo paper...I have removed paper, added, taken away, shoved the thing hard,...
have you taken and set the printer up to accept the correct size paper and did you load it in down? that should fix your problem, if not contact me and we/ll walk thru the proper sequence.
Dec 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper is not taken
check tray bath
change the pickup roller if NECESSARY
Mar 10, 2008 | Brother HL 1430 Laser Printer
HP LaserJet 1022 Printer Logo
117 people viewed this question
Seeker5211
Seeker5211
