Question about HP LaserJet 2840 Printer
Paper jam problem fixed after removing toner and removing paper, but also now getting auto showing as well and ready and the cartridge ink levels. Auto not their before and now not printing. No errors showing.
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever. Check the following video hope this helps you.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Posted on Oct 11, 2010
Please help me with printer jam
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you get toner or ink on your clothing, wipe it off with a dry cloth and then launder the clothing in cold water.
Watch out for loose toner or ink on jammed paper, and do your best to avoid spilling it on yourself or the printer. If a little bit of loose toner or ink gets in the printer, though, it should clear after a few sheets are printed.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
The paper is getting jammed in the printer every time.
Hello
Turn off the printer and remove any paper trays. Inspect them for wrinkled or damaged paper.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper, Don't force anything, though.
GOODLUCK
Jan 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Removed paper after paper jam and have opened all the doors to check everything, however it still reads 'switchback jam open front cover up scanner unit'
  • Step 1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  • Step 2 Turn off the printer.
  • Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • Step 6266_a1.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_b1.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • Step 7266_a2.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_a2.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  • Feb 19, 2010 | Konica Minolta Magicolor 4695MF All-In-One...
    Paper jam in rear feeder and now have erroe code 5700
    Steps to remove paper jam in Printers:
    Step 1
    Step 2
    Step 3
    Step 4
    Step 5
    Step 6
    Step 7
    Step 8
    Step 9
    If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
    Feb 19, 2010 | Canon MX700 Office All-In-One InkJet...
    Ran out of paper, tried to print four files and now the printer is completely locked up. All four top lights are on (Toner, Paper, Drum,. and Ready). The printer does nothing after going through every...
    1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
    2. Step 2 Turn off the printer.
    3. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
    4. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    6. Step 6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. Step 7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
    8. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    Nov 26, 2009 | Brother HL-2070N Laser Printer
    How do I fix a paper jam?
    Step 1
    some or all of the jam.Many printers provide an error-code listing
    on the front panel display for the area where the jam occurred.If
    jam occurred.
    Step 2
    Step 3
    Step 4
    Step 5
    If necessary,remove the toner or ink cartridge.Place it in a bag
    Step 6
    If you find a piece of jammed paper,remove it by holding it with
    both hands and pulling firmly.If several pieces are jammed together
    Step 7
    If the paper does tear,try rotating the roller gears manually to
    free the paper.
    Step 8
    Replace the toner or ink cartridge and paper trays,close any doors
    Step 8
    If the printer paper jam message still appears,then there is still
    some paper in the printer.Reinspect the paper path.
    Oct 28, 2009 | HP DeskJet 810c InkJet Printer
    My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
    give this a try
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    Unable to open to remove paper jam
    Step1
    Step
    Step
    Step
    Step
    5
    Step
    6
    Step
    7
    Step
    8
    Step
    9
    Sep 23, 2008 | Canon PC1061 Copier
    Paper Jam feeder
    Step1
    Step
    Step
    Step
    Step
    5
    Step
    6
    Step
    7
    Step
    8
    Step
    9
    Aug 14, 2008 | Dell 3100cn Laser Printer
    HP LaserJet 2840 Printer Logo
    243 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
