Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Have taken apart the makita bhp 451 hammer drill to try & repair but not sure where the 2 small pins go in the gear assembly. Any ideas or would you have a diagram of the gear assembly? Thanks!!
    New Friend:
The two "rollers" Rodino is talking about fit into the recess in the middle of the clutch/chuck housing. If you look there is a piece similar in shape to a wing nut that rotates to drive the chuck. The top and bottom of this "wing nut" are flat. The "rollers" fit loosely in the recess next to these flat sections.You'll know if they're in the right position as without them you can turn the gears with the chuck. With them in, they bind and allow you to tighten and release the chuck without the gears turning. Took a lot of experimenting to find this out.Good luck!!
Posted on Feb 02, 2013
Hi
If you are referring to 'pins' (about 10mm x .8mm) then these are stop pins. They sit into the clutch/chuck housing. If you look at the array of sprung pegs protruding from inside the clutch/chuck housing, you will see two small holes, diametrically opposite each other and very close to the sprung pegs. Those pins fit into each of those holes.
I hope this helps. If you are talking instead about two little rollers (about 8mm x 3mm) then i too would like to know where they go!
Thanks
Posted on Sep 05, 2010
  • Phil Steward Oct 21, 2012
    Did you find out where they go?
My makita hr3851 hammer drill will hammer but when switched over to hammer drill it stays in hammer mode. I have replaced the lever that changes from hammer to hammer drill and it still only hammers
134527-9 http://www.ereplacementparts.com/torque-limiter-assembly-p-54984.html?osCsid=h08big45jse6abdn6tcftrcnt6
How is the healt of this piece is it worn also the other part that will work together with this part must be replaced
Or hows the part connexion 221347-1 spiral bevel gear on the 152335-6 cilinder liner ?? i think its economic not interesting for repair because of the high prices. and the problem of discontinued parts in the prospect
Jun 09, 2015 | Makita HR3851 Electric Rotary Hammer
How do you take the chuck off makita bhp 451
After removing the screw lock the short end of a 3/8" to 1/2" allen wrench in the chuck. Firmly hold the drill on the edge of a bench or lock it in a vice so you can strike the allen wrench hard and fast. The screw is reverse threaded but the chuck turns lefty loosy like a regular nut and bolt. It's the best and only way to break the chuck free.
Sep 06, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Motor operates but drill has no power forward, only reverse.
you have a problem with the switch or the reversing lever. If you go to take it apart use caution that you do not disassemble the gear mechanism, you can find a breakdown and buy parts from them direct or they also have a locator at makitausa.com. I would look at the breakdown before trying to disassemble.
Aug 01, 2011 | Makita 8443DWDE Factory Reconditioned 18V...
Gears slip when drilling in all speeds although 3rd is the worst it applies to al setting settings as well screw, drill, or hammer. i've taken it apart the gears and visible parts are all fine none are...
As long as the shifter is fully engaging then you will need to replace the transmission. It comes as one complete assembly. Here is a diagram with part numbers. The trans is part #125433-9 (reference number 12) and is just over $53
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/BDF451
Jul 12, 2011 | Makita BDF451Z 18V Lxt Lithium Ion 1/2"...
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
How to pull apart makita 6980 impact wrench
the battery is removed. remove all screws around the outside of the drill/driver. the side comes off. the motor is a johnson motor connected to the planetary drive and hammer/anvil assembly. the motor drive extends inside the anvil via one gear off the motor. the hammer and anvil come out as one piece. if you depress the center of theanvil with an arbor press, two ball bearings come out and the escapment comes out with the spring. now you can clean the inside of the hammer and gears of the hammer drive.
Oct 20, 2009 | Makita 12V Cordless Impact Driver -...
Maikita bhp 451 transmissions
the gearbox is good,what the problem is,is the nylon speed change ring that goes on the outside of the gearbox that takes the power of the gearbox,the end of the teeth,about 2mm or less strip making only noise when in 2nd or 3rd gear,,they sell it with the new gearbox and charge you,,,,,but you can buy it separatly,,,the part no.419558-2,,pick key 01820914
Nov 02, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
804 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
