Question about Carrier 38CKC060 Air Conditioner
I have a Carrier AC unit with a heat pump. I noticed that it wasn't cooling and the circuit breaker had tripped. When I reset the breaker and try to start it again, it trips againafter 10 seconds. The outside unit fan comes on briefly, but dies when its tripped. I had the capacitor changed just 50 days ago and I'm thinking it gone again. Is that normal? What should I do?
    Problem Solver:
  • 19 Answers
Check with your contractor to see if their repair is warrantied. If it is not call someone who carries a warranty and satisfaction guarantee on repairs. It is likely that you got a bad capacitor, however, this typically will not trip a breaker. It's possible that other issue(s) caused the capacitor failure.
How old is this unit?
Posted on Aug 26, 2010
Any ideas as to why the panel breaker for my Goodman CPE24-1AB heat pump would immediately trip when the air conditioner is turned on?
Without looking up the specifications for this heat pump, I cannot be certain, but I expect the operation to provide cooling may require more power than when heating. You probably can find the specifications online for this unit. As you probably know, power is measured in watts and is calculated by voltage times current. This also is likely to be 240 volts operation. If you take the specified power on cooling and divide by voltage (240), that will indicate the current in amperage that will be required to start it. Your circuit breaker is set for current and needs to be a higher current than is required. If that is the problem, you can buy circuit breakers at Home Depot or Lowes. You have to remove the front panel of your breaker box and snap out the circuit breaker. To be safe it would be good to turn off the main breaker switch before you open the front panel and remove the circuit breaker for the heat pump. Should your calculation of current required be less than the rating of the circuit breaker, that implies a malfunction of the heat pump in the cooling mode and would require a service call to the local representative of the heat pump manufacturer.
May 16, 2014 | Goodman CLQ36AR49 Air Conditioner
Dry pad
Check for plugged holes in the top water distribution tray where the water from the pump exits to wet the pads.
May 04, 2017 | Mastercool 67680 Evaporative Cooler Air...
I have a Frigidaire air conditioner. I've never had a problem with it,at all until a few minutes ago. It all of a sudden quit working. I pushed the reset button and tried to push power, but nothing....
First check the outlet the unit is plugged into. It may be dead, due to a circuit breaker being tripped. Also, the interior of the outlet may be damaged or has a loose wire.
If a circuit breaker was tripped, unplug the unit before resetting the circuit breaker. Then plug the unit back in and turn it ON. If the breaker trips again, there may be a short in the AC wiring or there is another electric appliance on that same circuit, that may be causing an overload, when the AC unit is ON.
Hope this helps you to start troubleshooting the problem. Thanks for choosing FixYa.
Aug 10, 2011 | Frigidaire Heating & Cooling
I recently bought a used RV Carrier AC unit for my older camper. After installing the ac will work for about ten minutes before the breaker trips. If I reset the breaker the problem will repeat itself. ...
It sounds like the compressor is opening a thermal overload which is shutting the unit off. When the compressor cools down the switch resets and the process repeats itself. In the end it sounds like the system has a leak and is therefore low on Freon. This will cause the compressor to overheat and open the thermal overload. The freon cools the compressor windings and if it is low they will not be cooled sufficiently and hence the opening of the overload, which is a bi-metal sensitive to heat/cold.
If this has helped you please take the time to give me a rating on FixYa.com
Aug 03, 2011 | Heating & Cooling
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
Central AC unit sent smell and smoke film
thermostat can short out turning on system a short in wiring will do same --smoke can be from fan or circuit board have a mechanic service the system
Jun 11, 2017 | Carrier Adit 600 Base +24V Phone...
Carrier a/c tripping circuit breaker
I believe you are tripping the breaker because you are too close to the capacity of the breaker based upon the distance from the panel to the heat pump. If you are electrically skilled you could check this by measuring the distance and then looking at the standard to see. If this makes little sense to you, you may need to have an electrician check for u. Either way, good luck with it.
Feb 04, 2009 | Heating & Cooling
Carrier 38CKC060 Air Conditioner Logo
87 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
