Orient spit ac model os19 mdd display e4 error code
  • Amir May 30, 2017
    Whats the fault of e4 eror in orient invrtr a.c
HOU CAN REMOVE E4 ERROR PLEASE TELL ME, ANS
Posted on Jul 25, 2013
SOURCE: E4 Error code on APE07AHM1
I emptied the water tray. Viola!
Posted on Jul 17, 2008
SOURCE: SPLIT AC
PROBLEM WITH THE INSIDE FAN MOTOR
Posted on Feb 25, 2009
SOURCE: E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Posted on Mar 02, 2009
  • 400 Answers
SOURCE: my domain air 2.65kw portable ac unit - E4
Make sure the filter is clean and the pump is operating.
Posted on Mar 09, 2009
SOURCE: E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
Posted on Mar 19, 2010
Carrier AC Thermostat displays Error code E4?
E4 indicates an internal memory error. Download the manual and refer to any possible solutions.
May 10, 2015 | Carrier Heating & Cooling
It seems the compressor is not switching on the air con blows cold air but not as cold as it should be. It shows an E4 on the display.
Is this a house, a car, a portable AC? We can't help you look up error codes without a model number. Details pls.
Sep 25, 2014 | Heating & Cooling
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
May 07, 2009 | Heating & Cooling
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
Heating & Cooling Logo
671 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
