My washing machine stops during the wash cycle. The program switch needs to be turned a notch for it to continue with the cycle. It is not going out of balance as this happens while it is full of water even with a small load. The problem occurs in the middle of the cycle and straight after spin dry begins. It is a very annoying fault. What could be the problem and is it worth fixing?
    President:
  • 1,554 Answers
The program switch is actually the timer and there's a dead spot on it causing it to stop and needs to be turned a notch in order to continue. Fiddle a bit with it and it might clean off the dirt that is carding the dead spot. You have to replace the timer if the problem persists. It costs about $100 and it's definitely worth replacing and an easy task to do. Enter the exact model number of the machine here then under the part type, click Circuit Board or Timer for the exact pricing of the timer.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 26, 2010
  • 2 more comments
  • Jahn27
    Jahn27 Aug 27, 2010
    You need the one with part number 0574200164 but make sure it is the one for the model number of your machine.
  • Jahn27
    Jahn27 Aug 29, 2010
  • ivailo_grigo Aug 30, 2010
    Can you tell me where abouts this timer is in the washing machine. Maybe you can give me some tips in replacing it.
  • Jahn27
    Jahn27 Aug 30, 2010
    The timer is where the timer knob, or program switch as you call it, is attached to. The knob is attached to the timer shaft and it needs to be removed when replacing the timer. Pull the knob off then remove the console to access and replace the timer. Indicate the complete and exact model number of the machine for more specific and detailed advice.
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Washing machine would not start
On the lid is a switch that turn off the washer when the load pushes against the top. You may have over-loaded the machine.
Feb 26, 2014 | Indesit Washing Machines
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
Oct 15, 2017 | Washing Machines
My currys essential washing machine beeps during cycle and stops help
Remove the power for sometime , check if the spindle is FREE and moves. , Remove the back and under side to inspect for any damage to the motor or drive. check the power lines, check on the motor CAPACITOR. Now when powering check the VOLTAGE to the motor. if this is low or absent then the program controller unit is faulty.
Dec 31, 2012 | Washing Machines
WFL 1200 stop during wasking and diod is flashing
Sounds like the machine is not draining all the water or doing it too slowly, check the pump filter (if it has one) for coins, debris etc. Check that the outlet pipe is clear particularly if it is connected directly to the plumbing under the sink, remove the grey washing machine hose from the spigot on the plumbing and check both bits for obstructions. That machine also has a 'container' which is located at the top left (when looking at the back of the machine) this is between in inner and outer sections of the grey corrugated drain hose, this container could also be block. If the machine starts to flash before the rinses then there is also a possibility that the heater is faulty. You can test this by putting the machine on a cold cycle and seeing if it completes without a problem.Let me know if you need any further assistance
Nov 27, 2011 | Bosch Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Fisher & Paykel GW703 wont stop!
It sounds like your machine has been programmed to automatically run through the various cycles continuously. Most likely in error.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
