Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
All the lights are blinking when the door is shut but won't allow me to turn on. I have checked the power switch & reset my circuit breaker. Last time this happened (about a tear ago) Maytag instructed my to press certain buttons to reset the machine but the phone-support says they don't have that "code" anymore? Would appreciate any help. Thanks
I have model number mdbd850awb and this exact same thing happened to me on the weekend. i fixed the problem by total chance! I depressed the "off" button for a few seconds and it reset the control panel, now it's working great... i hope this works for you and saves you some time and money!
Posted on Sep 15, 2010
Dishwasher will not start
Make sure all the little doors and lids on the inside are properly shut. Make sure the main door is properly shut and the latch has caught properly. Make sure the power and water are on. Switch the power off and on at the socket just to make sure the controller is not locked up.
Nov 02, 2017 | Dishwashers
My Maytag MDB6160AWW finished its last cycle with a blinking "clean" light. I didn't think much of it. And somehow cleared the lights. When I filled it up and wanted to start a wash it will light up,
Blinking clean light is an error code does it blink 7 time pause then repeat that would be a heat circuit problem fast blinking a stuck key behind the lower panel should be a tech sheet explaining how to determine what the code is
Dec 24, 2014 | Maytag Dishwashers
Bosch dishwasher she43m06uc/48 constantly trying to drain. Cannot reset to end cycle.
Have you tried shutting off power to it from circuit breaker panel for about a minute and leave door open to dish washer . If that does not fix it the float Is stuck from grime build up . You can down load a maintenance manual online on how to access it and cleaning tips.
May 17, 2014 | Dishwashers
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
see this causes and fix it. God bless you
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
Dishwasher control panel unresponsive
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Hopefully some of that helps!
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
Hi, we have a square d 200amp ckt brker that we want to reset after we take our generator offline. we noticed that there is a black plastic tab that prevents you from resetting it. how can we reset it?...
Do you have a Square D "QO" panel - or a Square D "Homeline" panel (or a different brand panel completely)? If possible, please provide the catalog number of the circuit breaker.
Nearly all circuit breakers that are TRIPPED (handle is at the midpoint between ON and OFF) must be RESET by pushing the handle to the OFF position - then pushed the other way to the ON position. A circuit breaker that is in the OFF position, does not need to be RESET, and need only be pushed to the ON position.
It is advisable to shut off ALL the other circuit breakers in the panel, then turn on the 200 amp breaker. After the 200 amp breaker is on, turn on the largest value (in amps) double pole breakers and finally all the single pole breakers largest values down to 15 amps. This prevents switching one very large load all at once.
Aug 29, 2011 | Square D Qo 200 Amp 40 Circuit Indoor...
Power window on driver side stopped working and the door locks stopped working . Also this morning the battery was dead but nothing was left on.
It sounds like you may a faulty door lock switch. If you pushed the switch to lock the doors and the switch stuck and kept door lock solenoids energized, that would drain the battery. It would also keep the door locks from unlocking, as to why window don't work it could all be on the same fuse or circuit breaker. Usually the power windows are on an automatic reset circuit breaker. Do you hear click and a short time later another click (with the battery charged)? If so that the circuit breaker tripping then resetting. Good luck!
Dec 19, 2009 | 2005 Chevrolet Colorado
My oven door lock is in the out position. Oven door won't shut
Try shutting off circuit breaker for a few minutes to let control module to power down, then turn breaker back on. This may reset the control board back to factory default and retract the lock servo. If this doesn't work then a service tech will be needed.
Aug 01, 2009 | GE Profile JTP56 Electric Double Oven
Blinking "Normal" button
PROBLEM: STOPPED RUNNING, WILL NOT START AND
CLEAN LED BLINKS 7 TIMES, THEN REPEATS
(WATER HEATING FAULT)
Control is programmed to stop
running and not allow any
further cycles if it detects a
water heating problem (no
temperature increase detected
in heated Main Wash on
3 consecutive cycles). Control
blinks the Clean LED 7 times
repeatedly and disables the
Start/Resume key until
cleared.
Running Diagnostics clears the
control and allows it to operate
again. The water heating problem
must be fixed or the control will
stop running again. See potential
causes below.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater circuit.
■ Faulty heater drive circuit on
control.
1. Check operation of heater in
Diagnostics cycle.
2. Unplug dishwasher or disconnect
power.
3. Check resistance of heater and all
components and connections in the
water heating circuit or heat dry
circuit.
Wash pump not pumping water
past the heater efficiently.
See “WASH PUMP WILL NOT
PUMP”.
Door switch not making
contact consistently:
■ Faulty or sloppy door latch
assembly (which can be
aggravated by high door
closure force keeping strike
plate from fully seating).
■ Faulty door switch (high
resistance).
NOTE: Neutral switch on
plastic tub models is only in
series with motor and heater;
other loads are not affected.
1. Unplug dishwasher or disconnect
power.
2. Measure resistance of door
switch contacts while checking
mechanical operation of latch
assembly. Confirm switches not
loose from assembly. Check strike
plate and door closure.
Lack of water to heat. See “WILL NOT FILL OR LOW
WATER”.
PROBLEM: WON’T START AND START/RESUME K
Sep 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
312 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
