Question about Sharp AL 800 Copier
Drum light on
Drum light is on. I put a new drum and new cartridge in. Drum light is still on. It won't copy.
Lil
  • 3 more comments
  • spilde May 31, 2008
    There is a "C" button, and a "print" button. But no "C-photo" or "24-7"
    No luck.
    This is NOT a printer. It is simply a copier. (Actually, it was at our mission in Haiti, and I brought it home in April because it didn't work, to try to get it going again.) Have bought a new drum, and had a new cartridge, but the drum light continues to blink and it doesn't copy, even when the new drum is in.
    From the Sharp company, I believe. (It has been a couple of months since I bought it.) The numbers on it are: A61610901M. If it was indeed a clone, could that be why the copier won't recognize it? I'd hate to spend another 50 bucks for nothing!
    By the way, the drum light is flashing when the old drum is in, too.
    Think I should just dump it? Any ideas where I can get a good used (probably refurbished) copier to replace this one? Any brand you would recommend? (Nothing elaborate - the folks we work with have almost no repair skills - even less than me - and no resources for repair parts.) They have limited power, few computers, etc. but need a copier to help the teachers with materials for classroom work.
    Bemidji, Minnesota.
    I checked with North Country Business Products here, and they have no small used copiers.
    Genius:
  • 3,587 Answers
Ok..unplug the printer from the computer...and try it that way...you may need to re install the driver on the computer, and flash the memory from front panel on the printer..let me know after you recycle the printer.
Posted on May 31, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels May 31, 2008
    ok..sorry about that...well...where'd the drum come from that's a replacement?
  • Patrick Michaels
    sure..it's time..where are you located?
  • Patrick Michaels
    I know that town. did you try Minn/St. Paul?
    most office equipment folks will have something along these lines
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
Drum light flashes
This means that you will need to replace the drum soon. Order a new drum and when the light becomes steady or the print quality becomes poor, replace the drum. The drum should last ~12,000 pages. The part number is DR350. You may be able to order this from your Office Supply store; otherwise try the Brother Mall site: http://www.brothermall.com/Accessories/AccessoryDetail.aspx?AccessID=DR350&AspxAutoDetectCookieSupport=1 .
The procedure is similar to replacing the toner but instead of putting a new thing of toner inside the drum, you remove the toner and put it in the new drum. Open the front cover and pull out the drum and toner assembly. Place on newspaper or other disposable material (toner may spill). Push down the blue lever to unlock the toner cartridge. Remove the cartridge from the drum. Unpack the new drum (keep it out of the light until ready to replace the drum). Push the toner cartridge into the new drum until it locks into place; the blue lever should lift automatically. Put the assembly back in the printer. Clean the printer as recommended in the manual while it is open; this includes cleaning the corona wire before replacing the drum assembly.
After replacing the drum, reset the drum counter: with the printer on and the drum light blinking, open the front cover and press and hold the GO button until all of the LEDs light up (about 4 seconds). Then release the GO button and close the cover. Check that the drum light is off. (The manual says you should do the reset first but I tend to avoid this in case of distractions.)
I hope this helps.
Oct 06, 2010 | Brother HL-2040 Laser Printer
My printer drum light is lit and will not copy. I have put in a new drum and the is still lit and will not copy
Hi
Please follow the bellow instruction…
Open the front panel.
Remove the toner and the drum.
Remove the toner from the drum.
On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them.
Put everything as it was.
Turn on your printer.
Now, the low toner light should be gone and the green light should be on.
Now, you can empty your cartridge.
If the Drum light is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Open the front cover.
Locate the control panel button under the LED lights on the left side.
Pres the control panel button until all lights are lit, and then release it.
The Drum counter is now reset.
Thanks for contacting fixya.com
Feb 02, 2010 | Sharp AL-1540CS All-In-One Laser Printer
New drum wont work
It sounds to me that your maint counter needs to be reset. 24-7 will reset drum. Let me know if you need help getting into the simulation.
Feb 12, 2009 | Sharp AL-1530CS All-In-One Laser Printer
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
Won't copy anything now.
the "screen" is actually called a grid, it is supposed to be on a unnit called the "primary" which sits on top of the drum (long silver unit) it may have a screw holding it. It must have been serviced or someone touched it, does not come off by-itself, anyway, it distributes the charge of the primary to the drum.
So look for a unit that sits directly on top of the drum unit and is the same lenght as the drum
Hope this helps (please rate. TNX)
Oct 02, 2008 | Sharp AL 1631 Copier
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Sharp AL 800 Copier Logo
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
