Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer making a crazy noise - Maytag Neptune MDE5500AY Electric Dryer
  • 2 more comments
  • gmony73 May 09, 2008
    I have a EuroTech EDV158 Electric Dryer as well and it is making a loud grinding/motor noise. I have taken off the back and top panel and the belt seems to be just fine (good tension). Could it possibly be the motor going bad? There is also the smell of something getting too hot.
  • Anonymous May 12, 2008
    how to take the dryer apart
  • jazzbo red Jun 04, 2008
    ON INITIAL START DRYER SCREECHES LOUDLY FOR SEVERAL MINUTES; BELT(S) OR BEARINGS? CANNOT FIGURE OUT HOW TO REMOVE HOUSING TO CHECK! HELP!!
  • shhllc Nov 19, 2008
    We have an older Neptune model - MDE3000AYW. When running it makes a squeeling noise that can get really loud. Then, at times it stops making the noise but then starts up again. What is the probable cause?
Hello, shhllc,
The problem is with one of three pulleys. There are two "drum rollers" on which the dryer drum rests, and then there is a third pulley which keeps tension on the belt that connects the motor to the drum. Either of these can get squeaky when the grease dries out, or when they wear from prolonged use.To open this dryer, remove the front panel (either 4 screws inside the hinge mounts on both sides, or 2 screws along the bottom of the front panel) and check with a flashlight to find these three pulleys. With the dryer unplugged, jiggle each one... if it is loose from its axle, it needs replacing, otherwise, just lube all three pulleys by removing the retainer clip and wheel, greasing the steel axle with silicone (never use oil!), then replace the wheel and clip. You should enjoy blissful silence from there.
Posted on Nov 21, 2008
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 06, 2008
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
Hotpoint dryer making sqeaking noises still dries and rolls fine but noises driving family crazy
There are two main causes of dryer noises: foreign objects in the felt strips, and dried bearings. To relube the bearings, you need to disassemble the dryer and pull the drum. Inspect all bearings, including the belt tensioner.
replace what is damaged by wear.
Dec 13, 2010 | Dryers
GE WASHER 123C8381P001001 SPINS MAKING CRAZY CRAZY NOISE LIKE TO HITTING ALL AROUND
You can eliminate such problem by making the proper loading of fabrics to the spinner\dryer. Arrange the wet clothes properly not allowing any open space in the filling.
Nov 25, 2010 | GE Washing Machines
Dryer squeaks like crazy.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Kenmore series 80 dryer. everything works fine so far, just makes like a rumble noise as it is drying. driving me crazy. any solutions?
THE NOISE COULD BE FROM MANY THINGS. IS THE DRYER SITTING ON THE FLOOR SECURELY? HAVE YOU CHECK THE BAFFLE INSIDE THE DRUM? IS THE NOISE LIKE A CLUNKING NOISE AS THE DRUM TURNS? ALSO THE BELT MIGHT BE OFF ALIGN FROM THE MOTOR PULLEY, EVENTUALLY IT WILL TEAR OFF THE BELT.
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH THE PROCESS IF NEEDED.
Jan 16, 2010 | Kenmore Dryers
Dryer Making a Grinding Noise
My guess is either roller wheel(/s) have become FUBAR, or the idler pulley is worn. Either way you aregoing to have to open it up to find out what is going on...
Unplug the dryer.
If the filter is on the top of the dryer, remove it and remove the screws that are located underneath it. If it is on the inside of the door, remove the filter.
On the left and right sides of the washer, where the top panel meets the front panel, there are spring clips that hold the top to the front panel. You can slide a butter knife or spackling knife in the crevice and push them back so that the top can be lifted up (like a car hood).
The front is held on with 5/16" hex sheet metal screws, most likely. Remove it.
Now you can see what is the problem. You might be able to put some oil on the wheels to get rid of the sound, but this will most likely only be a temporary solution.
Jan 24, 2009 | Kenmore 75922 Gas Dryer
Roper (REX5634PQO) dryer will not start
This fuse mounts right beside the filter housing. Maybe you unpluge a wire while fiddling with the housing. If this fuse blows then the dryer will not run.8ab116a.jpg
Nov 23, 2008 | Roper REX4634KQ Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
428 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
