Question about Car Audio & Video
The radio stays on after the key is removed - Car Audio & Video
    Brigadier General:
  • 4,044 Answers
If yoru vehicle doesn't have a power timed circuit you may have it connected to a continuous hot that is allowing this to happen. In my Escape the radio will continue to play and I can power the windows up or down after I remove the key for 10 minutes or until a door is opened. If you remove the key with the radio on and it shuts off when you open the door you have a timed power circuit. If not you most likely have the radio wired to a direct Hot that is hot all the time.
Posted on Aug 26, 2010
MY RADIO STAYS ON WHEN I REMOVE THE KEY and close the door
radio stays on after removing key from ignition - Car Talk
community.cartalk.com/.../radio-stays-on-after-removing-key-from-ignit...
Mar 4, 2012 - this just started today and when i turned off my car and removed the keyfrom the ignition, the radio stayed on.
04 F150 - Radio stays on after key removed & door open ...
www.f150online.com/.../323659-04-f150-radio-stays-after-key-removed...
Mar 2, 2008 - You know how you can take the key out of the ignition (after turning off), and radio continues until you open the door? Well, yesterday I opened ... More results from www.f150online.com
Oct 22, 2015 | Chevrolet Astro Cars & Trucks
Have 1998 rava 4 radio stays on with key removed can only turn off with button clock stays lit all the time also pulling fuse turns both off
Could be that the ignition switch is not turning off the trunk line that feeds the radio,etc. Needs replacement.
Sep 01, 2015 | Cars & Trucks
When turn key ignition off radio and clock stay on
Even when you remove the key from the lock?
Try to turn the key a little more to the left to be sure to move out of the Accessory position.
Hope this helps.
Feb 25, 2015 | 2004 Nissan Murano
How do I fix the radio so it turn off when I take the key out a
does it shut off when you get out and close the door?? it should only stay on for a minute if its a factory radio.
May 16, 2014 | 2003 Ford F150 Regular Cab
How do I turn off radio
If you just turn the car off one notch, the radio will stay on. If you turn the key all the way off and remove it, it will stay on for a short time delay, OR until you open one of the doors which will shut if off with the key out.
Feb 14, 2014 | Dodge Caliber Cars & Trucks
SAfter shutting off the truck, radio and fan continue to run. Also, went out the other morning and found radio running without keys in the ignition. I tried replacing the relay switch in the fuse box. ...
Check and make sure the ignition switch is not worn out and allowing you to remove the key when the switch is turned backwards in teh accessory position. once the key is removed and the radio is staying on, turn the ignition without the key in it, both directions and see if it shuts off, if it does, menas work cylinder or key.
Nov 26, 2010 | 2003 Ford F150 Regular Cab
Jetta 4+radio stays on afterI remove the ignition key
Most radios will stay on until you open the door.
Dec 31, 2009 | 2003 Volkswagen Jetta TDI
2003 Altima radio stays on after removing keys from ignition
It very well could be the BCM....only way to check it is to have a full featured scan tool, and check out the systems.
Sep 30, 2009 | 2003 Nissan Altima
With the key off and the door open, the radio stays on.
The key switch is probably worn with two affects it may be you can remove the key before it is properly turned off or is worn internilay.
Aug 06, 2009 | 1986 Cadillac Seville
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
