Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Blinking light will not turn on
Hi my name is rick and I have a blinking green timer light on my tv it a mitsubishu Wd 62725 I replace 4 caps on pb and 4 caps on board with usb cable I do not know if that board call the dm board but the problem is still dear blinking green lights any solution will be appreiated please help me Thank You
  • juicey fish May 12, 2008
    mitsubihi wd65100
  • 80 Answers
Replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
Posted on May 22, 2008
Status light flashing red/green will not turn on loud sound.......help please!
Posted on May 12, 2008
Tv wont power up after replacing 6 caps 4 bad 2 looked good but were in series so replaced with larger voltage. mitsubishi wd 62725
That model will usually have 8 caps that require replacement on the Power board and also 4 capacitors on the DM board which will usually cause the Non stop blinking light symptom.
Sep 23, 2011 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking Green light after Capacitor kit replacement WD-62725
I just repaired two Mit WD-62725 sets in the last two weeks.
The first one had bad caps on the power board and the FMT board. The scond one had bad caps on four out of the five boards.
Also, on the FMT board, there was a blown surface-mount fuse.
I advise checking all of the boards for bad caps. If you fine a bad 1000uf cap, replace all of the 1000uf's on the board.
Hop this helps,
Dan
Sep 03, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green light no pic or sound
Hi Stan,
the blinking green lights is usually called The Blinking Light of Death
There is nothing much else you can do.
The problem is some swollen capacitors on the 5v line keep the microprocessor from booting up (the 5v is supplied to the micro).
The repair should not be over $250 to replace those 4 capacitors on the DM board/module.
They had a huge run of these sets with bad caps.
You cant do a error test because the micro won't boot. I'm afraid your options here are limited to calling for service.
be aware you can kill you tv by trying DIY, but click here for your fix.
similar tv, same problem, I'd leave it up to a pro though.
- justasnwers.
more info on the indicators:
http://www.hdtvoice.com/voice/showthread.php?t=52010
http://www.techlore.com/forum/thread/19524/Mitsubishi-WD-62725-Status-Light/?page=10
hope this helps,
regards,
voodoo
Jul 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
May 26, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much.  My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed.  I sure think Mitsubishi should be held more responsible than they seem to be.  Some one suggested a class action lawsuit.  I would sure join one.  Jack P
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Timer light blinking
Nov 11, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
460 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
