Question about Samsung Digimax D53 Digital Camera
Low battery display
Camera began displaying low battery and shuts off, even when new batteriers are installed.
  • pcokie May 13, 2008
    that took care of the problem. Thanks!
  • Anonymous Mar 17, 2014
    camera keeps showing low battery even with new one stalled
    Problem Solver:
  • 10 Answers
Go to your local walmart and but a set of nimh rechargeable batteries and let them charg when done charging install them in to you camra then hit the menu button go to the setup display and scrool down to the battery type and choose Ni-MH this will save you battery life from 5-15 min to 5-6 hrs of life.
Posted on May 07, 2008
My canon SX110 IS camera has recently started displaying 'battery is low' and flashing the red low battery sign even a few minutes after putting in brand new batteries. I have tried with several new sets...
I had the same problem with new batteries reporting as "low" and instant shut-off. After I found that it would stay on when plugged into USB, I suspected a firmware bug in the camera (I am a computer engineer). So I thought "how can I fool it?" I then found that it would stay on if you power it up with the rotary dial BETWEEN the video and manual ("M") setting -- in the "illegal" position. The after it's on, every mode works!
--Dan S.
Ithaca, NY
Oct 22, 2010 | Canon PowerShot SX110 IS Digital Camera
I have a Canon A590 Low Battery even with new batteries installed
Use NMH type batteries standard batteries are not good enough for the write load that this camera draws. I think it recomjmends this in your manual if you still have it.
also dont use rechargables
Please rate my help++++Thyanks for using FIXYA
May 09, 2010 | Canon PowerShot A590 IS Digital Camera
New batteries but displaying low battery and camera shuts off
I was using batteries made for a camera.
Suggested getting just energizer batteries and now the camera works.
Nov 23, 2009 | Aiptek IS-DV2 Camcorder
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
Aug 18, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
May 18, 2009 | Panasonic Cameras
Battery Problem
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Jun 16, 2008 | Canon PowerShot A640 Digital Camera
Low battery display
i had a similar problem...my lense woudnt go back in either, but it kept saying low battery and bleeping. I realised that my lense was stuck skwint, and that was what was causing the problem, once i straigtend up my lense it folded bak into the camera and worked fine wen i turned my camera on :D
May 06, 2008 | Samsung Digimax D53 Digital Camera
New Batterys and camera indicates batterys low then shuts off.
Did the batteries come with the camera? If not, they might not be a high enough mah rating. Some batteries, even though brand new, may not be strong enough to power a camera.
Dec 06, 2007 | Kodak EasyShare CX7530 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax D53 Digital Camera Logo
219 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
