Question about Tally Line Matrix T6045 Printer
How to print a pdf text document in text mode
Whats pdf? do I need to download this?
Hi, Jane PDF is a file format that provides an electronic image of text or text and graphics that looks like a printed document and can be viewed, printed, and electronically transmitted.
Aug 29, 2017 | ScanSoft PDF Converter Professional...
How can i get my printer adjust to eco mode
Set up your printer to save ink and paper (ECO MODE)
Step 1. To specify print settings in any open application go to File, Print or File, Print Preview, then choose Print Preferences. The options available will vary depending on the printer model you're using, but you'll probably be offered the ability to print in Draft or Economy mode and to a set page range.
Step 2. If you're printing long documents, reduce the page margins to fit more lines on each sheet. Open the program the document was created in and alter the margins in the document settings. Alternatively, you may be able to reduce the margins using the ruler guides. In WordPad, you'll need to look in the Page Setup menu.
Printing Advisor Printer reviews
Step 3. One way to save paper is to print more than one page of your document on each side of paper. Your printer will almost certainly have settings for this, and you may also find them within the software you're using. Be sure to check that the resulting text isn't too small to read, however.
Step 4. Duplex printing is the term used for printing on both sides of a sheet of paper. Not all printers are equipped with this feature, but it's a useful way to conserve paper and produce professional-looking documents. Carefully consider whether you want to flip the page on the long or short edge.
Step 5. Most programs have a print preview feature; use this to see how your document will look on the page before printing it out. You can tweak your page as much as you like, only making a final printout once you're happy with the result. This can save money on paper and ink usage, as well as reducing the wear and tear on your printer.
Step 6. Third-party software can help you reduce the amount of ink you use. InkSaver costs £20 or you can try it free for 15 days. We also like the look of the soon-to-launch Ecofont, which perforates text with holes that are invisible to the ***** eye in order to use less ink.
Print to PDF rather than paper
Step 1. A PDF is an exact electronic version of a document that's viewable on almost any device. A PDF protects the original document from editing by the reader, making the format ideal for marketing materials and digital magazines. Download and install the free version of Nitro PDF Reader.
Step 2. Nitro PDF Reader installs a printer driver that lets you export a document to PDF from any application's Print menu. To create a PDF version of your document, simply choose File, Print and select Nitro PDF Creator (Reader) from the list of available printers. Press Print and enter a name for your PDF.
Step 3. For greater speed and convenience, Nitro PDF Reader offers simplified, one-step conversion. Drag your chosen document from Windows Explorer on to the Nitro PDF Reader desktop icon. The conversion will begin at once, with the resulting PDF saved to your desktop.
Step 4. As well as exporting documents to PDF, the software lets you view them - if you're opening more than one then they'll appear on different tabs. Longer documents can be viewed as multiple pages by selecting the Tasks tab and then choosing between Single, Continuous, Facing and Facing Continuous views.
Jul 22, 2017 | PRINTER Office Equipment & Supplies
Why Can't I print documents?
What application are you printing from?
Are you trying to print a PDF with a lot of scanned images or embedded content? Large PDFs can bog down printing.
Try to find a simple text-only PDF (no graphics or scanned stuff) with only a few pages and print it.
Some third party PDF generators do not make clean PDFs. They are malformed and can cause issues when printing.
Jun 07, 2016 | Epson Stylus Office Equipment & Supplies
Format pdf file into readale text file so that I can print it to answer Na QUETIONS
Not sure why you want to convert PDF to text.
Try to highlight the text in the PDF, copy and past into another document. Otherwise search the Internet for a PDF to text converter. There are some but hard to find one for free. Also, beware of free software.
The problem is that PDF documents were made so they can be viewed on any platform with any computer and still look the same and there is security built into PDF documents so they cannot be converted.
Apr 11, 2014 | Computers & Internet
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Printing problem with pdf files
Open the pdf document.
Click on File-> print-> click on Advanced tab on the print dialog box.
Click on checknext to "print as Image" and click on Ok.
Then click on Ok.
Then try to print.
May 26, 2010 | HP LaserJet M1120 MFP All-In-One Printer
HP OFFICEJET PRO K5400 - COMMISSIONED FRIDAY OCTOBER 17 1) TODAY OCT 21 PRINTING PDF DOCS TEXT WITH COLOUR PICS, PRINTED SEVERAL COPIES OK, PRINTER STOPPED PRINTING THE PICTURES. AFTER SEVERAL ATTEMPTS...
Try this !
in the software application you are printing from
Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
Look for a Best Mode Setting
this printer has several modes one being draft mode, another one best mode
in best mode the printer uses memory to render the photo you are trying to print.
Note that in this mode, printing takes
longer and more memory is required from your computer.
from page 17 of the hp k5400 user manual
Also you may have to increase the virtual memory of the windows pc to allow the computers hard drive to allocate more hard drive memory to the memory swap file if the computer's ram is not enough to print the photo.
It is a setting in the control panel under system - performance.
May 12, 2017 | HP Office Equipment & Supplies
Help with adobe 7.1.0
In order to edit a PDF document, you will need either one of Adobe's commercial Acrobat products or a similar third-party application.
You can often copy the contents of a PDF document to a word processor or text editor program (e.g., Microsoft Word or Notepad) and then edit them, but in this case you cannot resave the document as PDF (unless your word processor specifically has the ability to create PDF files).
To copy the document's contents:
from the Adobe Reader Edit menu,
choose Save as Text.
Alternatively, from the Edit menu, choose Select All; then, from the same menu, choose Copy, and then paste the text into your word processing program using that program's paste function.
May 07, 2008 | Adobe Acrobat 7.0 for PC
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Tally Line Matrix T6045 Printer Logo
91 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
