Question about Audio Technica AT-PL120 Turntable
I'm a dj and I use the Auido Technica AT-PL120 as turntables. The problem is that when I mix, the pitch speed would increase and then eventually go down to the actual speed whithin seconds. I didn't have these problems with other turntables.
  • 189 Answers
Before anything else I would clean the pitch slider control with a little bit of De-Oxit D5 cleaner or Servisol. It could be there is some dust/dirt in the slider control causing a fluctuation in speed because of bad contacts.
Spray a little in the slider, work it a few times and leave for about 5 minutes before trying. Hope this helps :)
Posted on Aug 28, 2010
Where can I purchase a replace tonearm locking clip for an Audio Technica AT-PL120?
Audio technica will send you a replacement clip free of charge. Just send their service department an email asking for one.
Feb 21, 2012 | Audio Technica AT-PL120 Turntable
I'm trying to figure out what type of cartridge the ATP-2 is which came with my Audio Technica AT-PL120 Turntable. Is it "Moving Magnet" or "Moving Coil" or something else?
These are the specs for your cartridge - it is of the moving magnet variety. Vector-Aligned Dual Magnet design and A-T's exclusive Paratoroidal signal generator. This unique signal-generating system is composed of a unified, laminated coil core wound with a single piece of wire. Internal mechanical and electrical connections are eliminated, minimizing magnetic losses and assuring better signal transfer. PCOCC wire
Cartridge Specifications (ATP-2)
Frequency Response 15-22,000 Hz
Channel Separation 23/17 (dB at 1 kHz/10 kHz)
Vertical Tracking Force 3.0 - 5.0 grams
Stylus Construction Bonded round shank
Output 5.3 mV at 1 kHz, 5 cm/sec
Channel Balance 1.5 dB
Stylus Shape 0.4 x 0.7 mil elliptical
Cantilever Alloy tube
Jun 14, 2011 | Audio Technica AT-PL120 Turntable
How do you replace the tone arm rest (plastic holder/lock) on a Audio Technica AT-PL120
Hi, there is a screw that fits up underneath the clip that needs to be undone to remove the tonearm rest clip. styluscity@gmail.com
Sep 13, 2010 | Audio Technica AT-PL120 Turntable
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
Brand new audio technica at-pl120 turntable not powering on; cant get turntable to spin
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Jul 12, 2009 | Audio Technica AT-PL120 Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
What do I need to hook up the AT-PL120 to an imac
I use Audacity. It's a 100% free sound editing software and works great for vinyl transfers...Linky
http://audacity.sourceforge.net/download/
Jun 16, 2008 | Audio Technica AT-PL120 Turntable
Audio-technica atp-2 cartridge with a atp-n2 stylus
Make sure the cart is connected properly, and check the manufacter's instruction with that cart. sometimes tonearm height and weights need to be adjusted for proper torque and sound.
Oct 26, 2007 | Audio Technica AT-PL120 Turntable
Audio Technica AT-PL120 Turntable Logo
65 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
