Question about Fuji FinePix A360 Digital Camera
When i put batteries in my camera i can hear noise like it wants to work but im not sure whats going on with it and im trying to get is fixed. Is there any one i can send it to to have it fixed?
  • 3,866 Answers
This noise is your lens motor it might be stuck into place thus the camera will not turn on, however you did not leave a zip code so i will give a internet site you can send it to for repairs.
click here for the repair site otherwise you can take it to a local camera shop.
Please be considerate and leave ratings and feedback before you go, Thanks for using fixya.com
Posted on Aug 26, 2010
  • Fuji Master
  • 6,826 Answers
Just received my new Kodak Easy Share C142. It makes intermitate noise when it is turned on. I just put the batteries in that I received in the box so I assume the batteries are good. I have also turned...
This noise your hearing is probably the auto focus (AF)
But please confirm what type of noise you hear, update me with this information.
thanks for using fixya.com please do make sure you leave positive feedback and ratings.
Aug 31, 2010 | Kodak EasyShare C142 Digital Camera
I have had my canon 870is for about 1 1/2 yrs & love it-I have never had any problems until today-the battery flashed red(dead) & I removed it & charged it...Well, now since I put it back in...
Depending on how long your camera has been put away for, and in what conditions it could be either with the camera or the battery itself.
If the battery is older it won't hold the charge, so even charging it and immediately placing in the camera it won't have enough energy to power it on and stay on.
You can try to purchase a new battery for the camera, make sure it is the manufacturer indicated battery. Often people try other batteries and they don't work. it does make a difference.
This company is very reliable http://www.teleplancamerarepair.com/Canon_Powershot_SD870_IS
and they also clean the camera as part of their repair services.
Make sure you tell them what is going for it could be something with the built in flash, or a camera sensor.
Try the battery first.
Jul 13, 2010 | Canon PowerShot SD870 IS Digital Camera
I just recently purchased my camera. It worked the first time I used it, now it will not turn on. I have replaced the batteries to be sure this was not the problem. What is going on? I have put my ear up...
Normal batteries it's not working for me!
You must replace standard alkalines with rechargeable NiMH batteries Sony or Varta 2700 Ni-MH. For me it's was working!
My camera it's turn on every time!
Mar 13, 2010 | Fuji FinePix A850 Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
When I switch camera on, lens comes out but no screen display and I hear a hissing noise. Any idea what is wrong
Unfortunately it sounds like a hardware problem.
Just to make sure, let's reset the camera.
Take the battery out, leave it out for 24 hours.
Put it back in, turn on the camera, and see if it works.
If not, it is indeed a hardware problem, and you have no choice but to send it in to be repaired.
Hope I helped!
Tom
Jun 20, 2009 | Pentax Optio S4 Digital Camera
After plugging into mac it will not turn on or get anything up on screen, completely dead
I just had this same problem happen to me. I was able to solve it by doing the following. I'm not sure if all of these steps are necessary, and I suspect not, but this is everything, just in case.
1. Take out battery and memory card. Hold down power button for 15 seconds.
2. Plug in camera dock, put the battery but NOT the memory card into the camera, and then put the camera in the dock.
3. Push the PHOTO button on the dock. The camera should beep once. If there are any pictures saved on the internal memory, they will show up.
4. Disconnect the camera and it will turn off.
5. Put your memory card back in, and put the camera back in the dock.
6. Push the PHOTO button a second time, and scroll through a few pictures to make sure you are able to access the ones on your memory card.
7. Take camera out and turn it on. You should be all set.
It's possible that you really only need to do the last 1-3 steps of this process, but in any case, this got my camera to turn on again. Hope the same works for you!
May 01, 2009 | Casio Exilim EX-S500 Digital Camera
My samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Hi i have f80 camera film and the lense it doesnt work,cose it fall dawn,so how can i fixe it or if u have one to buy it how much the cost for that ?thank you
Your question is in the title so I cant see your whole question. so I hope this helps.
Im going to guess your lens is not Auto Focusing?
Then First I would make sure the switch on th side is set af for auto focus. then I would check the connection. take the lens off and then reconnect it and make sure you feel or hear it click. if that doesnt work try changing the batteries even if the battery meter says they are good. Sometime the battery meter will get stuck.
I hope that was you question.
If not then contact me and I will answer your other question,
caleb
Jun 25, 2008 | Nikon Cameras
My camera makes a grinding noise please help
sounds like the Zoom mechanism is getting stuck (the system is trying to protect the mechanism by shutting off).
you need to send this off or take it to be fixed. these compact digital cameras seem to have problems like this all the time,
Aug 27, 2007 | Olympus FE-170 Digital Camera
Camera is making strange noise
Good Day, lens assy problem, no longer user serviceable, contact nearest svc ctr. thanks
Dec 28, 2006 | Sony Cyber-Shot DSC-P73 Digital Camera
Fuji FinePix A360 Digital Camera Logo
20 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
