Question about Kenmore HE2 Plus Front Load Washer
My washer keeps saying F-01. what do i do? - Kenmore HE2 Plus Front Load Washer
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
If you reply using the "Continue with this expert" option - I can assist you in ordering the correct part.
Thanks for using FixYa!!
Posted on Aug 26, 2010
It says error 01
Error code 01
Leak Detected - When water is detected under washer
tub.
Dec 16, 2010 | Electrolux EWDW6505GS Fully Integrated...
On my washer machine appear code F-01, what that mean?
Under the front panel on the bottom of the machine is the error code manual. Mine says a CCU replacement for the F-01 error code.
Nov 22, 2010 | Whirlpool WFW8300SW
What does f-01 mean on the hotpoinr washer
"Error F01" is indicating that the motor triac has short circuited on main PCB, this is part of the electronic speed control for the motor.You can do simple checks like motor connections/brushes etc.If the connections are seems to be perfect check the wiring whether it has continuity from motor to PCB. If there is no continuity then the PCB is faulty.
Hotpoint's advice is to call an engineer, it is not really a DIY repair, unless you have a good knowledge of electronics.
Thank you !!
Jul 27, 2010 | Hotpoint Ultima WD72 Front Load...
It keeps coming up with F01 error when we start a load we turn it off and on a couple of times then it works and then it comes up again when rinse cycle comes on
Hi
" reset it : hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesnt always work 1st time so keep tryingater will leak into the gearcase shaft and ruin it
OR
take the front panel off the bottom and the error code manual is inside. Mine says a ccu replacement for the F-01 code
Thanks for contacting fixya.com
Oct 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sprocket chewed up
Here is the kit (122520-01), it contains all the pieces you wanted plus the star washer (item 9) for $9.99.
http://www.remingtonpowertools.com/product_detail.cgi?file=11.246
Try calling Remington 866-206-2707
Under parts says you can get an entire refurbished unit for $59.99
Lou
Sep 21, 2009 | Remington Electric Chain Saw
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-01
i went on to the hotpoint website which told me what was wrong
Sep 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
