Question about Maytag NMPEB08F2A Air Conditioner
If the air isn't cold anymore do I need to add more water or something else? If yes how
  • Maytag Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
Compressor isnt getting single to turn on
Yes , usually the PCM / ECM - engine computer gives the relay a ground . But the PCM needs to see the correct inputs from the high an low pressure switches to do that ! You could have a bad switch . Look on the A/C system pipes for switches , with two wires each ! One side should have 5 volts , an the other side i'm not sure .
Apr 08, 2017 | 1992 Nissan NX
On my 2004 gmc sierra 1500 the compressor cycles on and off. i tried to add more freon but it would not take the freon so i changed the low pressure switch but still doing the same thing. could the orfice...
When the compressor kicks on, is the air from the vents blowing cold? If the air isn't blowing cold, then your problem could be that you may have water in the system. I had a '93 Chevy Z71 that wouldn't blow cold and thats what my problem was. System needs to be evacuated and refilled. Good luck bro.
Aug 14, 2012 | 2004 GMC Sierra
Does the GE a/c asr05lcs1 take water
No you do not add water to A/C unit,its job is to remove moisture from the air,so make sure it is draining out the back ,if it wont blow cold after that get rid of it ac units are not to expensev anymore good luck
Jul 21, 2012 | GE ASR05LC Air Conditioner
Air conditioning isn't as cold
You will need to have the AC pressures read to see if the charge is low. DO NOT just add refrigerant unless the pressure's indicate it is the problem, you can destroy the AC compressor very quickly. (1st hand knowledge)
Jun 16, 2012 | 2006 Hyundai Elantra
The car is overheating and blowing cold air out of the heater. replaced the thermostat and still haven the same problem. what else could i check for?
it sounds like either your head gasket has gone or your water pump is not working correctly. try taking off your radiator / expansion tank cap and turning over engine, if the water is pushed out of the tank your engine is pressurising, a sign of blown head gasket. to check the water pump is not as easy. check to see if the radiator is getting hot and fan cutting in.
Jan 24, 2012 | Cars & Trucks
Refrigerator isn't getting cold anymore
Check if the compressor is running. If not, test for power to the compressor. If the compressor feels very hot, and you hear something clicking, then you probably need a new starting relay which is inside a little box on the side of the compressor. You might have to wait several minutes for the compressor to cool off before it will do its next "click-on" and "click-off" thing. If the compressor is cool, and there is power going to the relay, the overload (next to the relay) could be "open" (no continuity).
Sep 07, 2011 | Beverage-Air CT96Y1B (6.8 cu. ft.)...
Freezer and fridge not cold at top! Bottom of freezer is staying frozen but ice in icemaker is melting. Compressor is running fine, just not getting cold. Water was not coming out of water dispenser. ...
Are your evaporator fans working?
Since I am not there I can't take a look at it and tell you with certainty that this or that is the problem, but I can tell you a few things to check to localize the problem.
If the cooling fan is not operating, there is nothing that will force the even distribution of cold air, and since cold air falls, it would make sense that both the refrigerator and freezer sides are cold but the upper areas are not. So that is the first thing I would check, if it isn't working, then you will need to find out why.
A second possible is that something is wrong with your defrost circuit (probably timer) and your defrost heater is constantly on.
Either of these possibles could cause the problem you describe.
Jul 05, 2011 | Frigidaire FRS6R5EMB Side by Side...
I have a Electrolux Intuition plus freezer/refrigerator, and freezer is working properly but refrigerator isn't working anymore (but light inside still works) but it is not cold inside anymore, what...
A clog on the refrigerator side will cause that. Check if there's a lot of things loaded into it. Usually cold air from freezer will going down up to the bottom of the refrigerator if there's no hindrances or blockage like food stuff, fruits, vegetables, etc. load, it should therefore be cold.
Arrange correctly the things you loaded so it will not blocked the cold air dropping and it will reach the bottom side of the fridge.
Good luck.
Jun 24, 2011 | Refrigerators
Air condtioning on civic
Yes, that could possibly be your main problem when dealing with the blower motor and compressor, check the relay box and the fuse box inside the car itself
Sep 07, 2008 | 2001 Honda Civic
Maytag NMPEB08F2A Air Conditioner Logo
127 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
