Question about Lexmark X2500 All-In-One Printer
Lexmark x2500 all in one ink refill problem
How do I know which hole on back of black #28 cartridge is the one to punch out to refill?
    Guru:
  • 1,463 Answers
This might help you .
x2500
riz.
Posted on May 13, 2008
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Where do i inject the ink in my cartridges on a lexmark printer. i need to refill both cartridges. i have the black and coloured ink, and the syringe, however i dont know where to inject.
    Usually the refill kits come with instructions that cover many cartridges.
    A lot of the lexmark's use HP style cartridges and those often you lift the label to access the fill holes.
    FILL SLOWLY and do not over fill. Usually the cartriges hold so many ml and youcan measure that on your syringe. Knock off a few ml from what they say the cartridge takes.
    Nov 11, 2009 | Lexmark X2500 All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    DO YOU KNOW WHAT INK CARTRIDGES ARE COMPATIABLE WITH LEXMARK X2500?
    according to the lexmark website....
    28 black
    29 colour
    28a black
    29a colour
    34 high yield black
    35 high yield colour
    hope this helps
    Oct 14, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark printer always want a new cartridge
    What you need is to reset the ink level:
    1) Goto the Lexmark Solution Center application.
    2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
    Hope this help.
    YBC (/\)
    May 28, 2009 | Lexmark X2500 All-In-One Printer
    I cannot get my printer to recognize my refilled ink cartridges
    “Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
    Apr 20, 2009 | Lexmark X2500 All-In-One Printer
    Refilling lexmark cartridges x2500
    There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
    Aug 10, 2008 | Lexmark X2550 All-In-One Printer
    Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
    Jun 03, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark Black cartridge 28
    You cannot refill a 28 that has been through a refill program. Look at the box dose it say refill program cartrage ?? then you can't refill it, it will always say empty.
    You can however refill a 28A.
    May 13, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X2500 All-In-One Printer Logo
    345 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Sanath Kumar V
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
