I cant get acces to my Modem or Wifi using "192.168.0.1? Help
  • 75 Answers
May be 192.168.0.1 is not the address to configure that router.
Start, Run, CMD to open a command prompt:
Type the following command:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
example results.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Adamprince>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Adamprinces
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine III Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-0A-48-08-24-52
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 202.27.184.3
Lease Obtained. . . . . . . . . . : Tuesday, 24 August 2010 5:35:33 p.m.
Lease Expires . . . . . . . . . . : Wednesday, 25 August 2010 5:35:33 p.m.
____________________________________________________
The address to configure that router is 192.168.1.254
Posted on Aug 26, 2010
Hp a345w desktop pc dcs server not found conflict
what OS, we can NOT GUESS your operating system.
so where are you , home or star bucks.?
what is your connection, wifi, ethernet, or others?
a desktop pc can have vast ways to get internet.
1: modem dial up (i bet not this, nobody uses this now, 99.9)
2: cable modem, sat modem, fiber modem to ISP
3: USB wifi dongle, on PC and to local router.
4: PCI card wifi. , to router.
5: ethernet wired to router or modem direct. a cable wire. CAT5/6
one can even have direct wired ethernet to the cable modem
or you might have wired to wifi router (2 ways to connect there)
NO OS stated
no connections stated.
my guess is DCS, means DHCP not found, or DNS not found.
lots of causes, but I will not attempt to answer for all 6 ways.
sorry
May 30, 2017 | HP Computers & Internet
Cant hook my laptop wifi to cable modem
who should help you ??????????
nowone is able to smell what laptop or modem you use.
I....!!!!!!!!!!!!!!
Mar 12, 2013 | Computers & Internet
I cant get wifi and internet on my computer at the same time
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
Feb 28, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
I have acer laptop 5580. 3 year old. Recently i have installed Windows 7. Wireless was working nice. Now, system is identifying the wireless, but not connecting. After troubleshooting it is giving...
If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
May 09, 2011 | Acer (BCM94318MPG) Wireless Adapter
How i can setup Wifi to Thomson (DCM305R) modem?
Hello, Thanks for the opportunity to help you.
First off you modem there is not wifi but cant be hooked up to a wifi router that you can purchase from any computer store.
The modem would hook up to the router directly instead of hooking to the computer via RJ45 "ethernet cable"
The wifi router would then share that connection. You would need to set that up with some security I recommend WPA 2 encryption you will need to select a password/ or pass phrase.
In order for me to give you the How To's we would need some more information such as:
1. Brand name of router
2. Model number
Click here for some basic information on how to hook up a cable modem to a wifi router.
Thanks for using Fixya.com , We hope your found this Very Helpful.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 25, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
I cant get wifi on my pink sylvania netbook..... i have a computer( desktop ) with a modem and i have an ipod touch with wireless (betgear ) but my sylvania cant find any connection
Take a look at the video at: http://www.youtube.com/user/dgsupprt#p/u/7/4m6T81LX7n8
but before you do that take a look at my TIP at: http://www.fixya.com/support/r7957741-sylvania_synet07526_owners
To be sure that thoseentries are not causing you problems.
It has been many years since I used a modem and am not altogether sure that it has the ability to foster WiFi. If you are referring to a modem as the Cable modem, then it should have built in WiFi access and the detail presented will work for you.
Jan 19, 2011 | Sylvania G-Netbook
My ipod touch wnconnect 2 wifi can you help
Dear, I had the same problem with my iPod. It's because (I guess) your modem/router has MAC adress filtering. You need to get your ipod full acces through you MAC filtering. To know your iPod's MAC adress, go to: Settings > General > Info > (scroll down) Wi-Fi Address. If you give me some more info 'bout your router/modem, I'll search some more info.
Kind regards, FriskYR
Feb 04, 2010 | Apple iPod touch
I have the mc 70 how do i get started if i wanted to send my orders using wifi
i thank that you have to configure you acces point first, and configure also your unit to communicate with your acces point in setting( ip adress,subnet mask,ssid,keys...) and and connect your acces point to your system( switch,modem ,,,)
Feb 03, 2010 | Symbol MC70
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
