Question about Marantz PM7200 2-Channel Amplifier
1974 marantz model 2325 reciever and want to hook up a powered subwoofer ?
  • 1,512 Answers
Hi jdwoomer
BEST WAY
Your amp has PreOut and Main In RCA connectors on the rear, you could make up an adaptor cable (or buy one) to split the post vol control signal at this point, and then use line level from here to drive the sub.
OR
Most powered subs have a speaker "high level" input, where the sub "sniffs" off signal from your speaker output. When setup like this the speakers and amp connect to the back of the Sub.
Either way, you can do it... Marantz were making nice gear back then... a collectable these days :) Any questions, I am here to help.
regards
robotek
Posted on May 07, 2008
Connecting Marantz Power amp to Marantz reciever
Please see my answers regarding the hookup of Marantz amps and preamps.
Feb 21, 2014 | Marantz MM7025 Amplifier
Marantz NR 1403 & Preamp - Volume cannot be controlled by receiver
The newer surround sound recievers will not work no matter what you try with them the way you have it hool up, they are not design to be useing a turn table on them that has a mgnetic cartridge ,Evan if you buy a phono preamp for it, you are just wasteing your time end money, I was a electronic tech for over 40 years ,Before i retired this summer, End no lots of people who tried to do the same thing your trying to do ,End It would not work,
Nov 26, 2012 | Marantz Audio Players & Recorders
TRYING TO HOOK UP MARANTZ SR4000 TO A MITSUBISHI HC300 TO DIRECT TV. HAVE PICTURE BUT NO SOUND
Try changeing around your patch cords,You probaly have the input end output patch cords mix up.If they are not hooked up right you will get no sound. Unless there is a problem with the jacks on your amp or reciever
Sep 20, 2012 | Marantz SR-4000 Receiver
I have a marantz sr 7001 amp and am running canton 4ohm speakers to front and centre should my amp get really hot and go into protect mode when I am giving it some serious volume
it is not made to drive 4 ohm loads.also if you measure the impedance on the speaker,at some frequencies,it is closer to 3 ohms.This will cause the amplifier to shut down.Today's amplifiers are embellished specs.the old marantz 2325 was 125 watts a channel and weighed 80 pounds.It would eat alive some of the 1000 watt home theater amps of today.Marantz is very nice stuff.
Jan 03, 2011 | Marantz SR-6300 Receiver
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
I want to connect my Marantz 1030 amp to a yamaha YST-SW012
use the left input on the sub. It acts as the main input. Hope this helps
Nov 19, 2009 | Car Audio & Video
How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Feb 10, 2009 | Marantz PM-68 Amplifier
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
Marantz PM7200 2-Channel Amplifier Logo
308 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
