Question about Kitchen Ranges
Westinghouse Avondale 4 plate forced fan oven,Tag shows Email P/L Model: PAF 529 B 00, Ser 534 06684, 9.3 kw FORCED FAN NOT WORKING.
  • 1073 Answers
SOURCE: I hate my Westinghouse Fan
in the owners manual with most of the ovens it will tell you haow that you can vary the temprature of the thermastat 50 degrees up or down but not 100 you can try that and if it does not fix the issue then you will have to replace the oven sensor
Posted on Apr 27, 2008
ngfam1
  • 639 Answers
SOURCE: wehave a eurolec 3572 9
I'm Neil
No problem
Sounds Electronic
There may be an electronic problem !
Call service!
Thank You for asking!
Neil
Please rate my solution
Posted on Aug 24, 2008
ngfam1
  • 639 Answers
SOURCE: GE OVEN HAS QUIT WORKING...F7
Hi Rayham,
Happy to help you!
THIS IS AN OLD MODEL AND I WOULD NOT SPEND ALOT OF MONEY FIXING IT!
TRY THESE GUYS
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
  • 1462 Answers
SOURCE: Miele Oven H316 When using
element should glow dull red when on fan oven but not bright red. are you sure fan is operating? remember there are two fans - oven fan and casing fan and you may be listening to casing fan
Posted on Nov 17, 2008
SOURCE: steps required to replace 2200watt
Symptoms= Oven light ok, thermostat light ok, oven not heating at all or to a low heat. May also have tripped the circuit breaker on the switchboard
Probably the element
Switch off power to the oven at switchboard
Open the oven door just a little and pull the door up to remove it.
Lift the panel at the oven back wall over the fan.
See the coiled element, you may already see a defect in the surface of the element.
Remove the screw at the base of the coil
With a small sharp screwdriver flip out the clip on each side of the element at the top
Feed the element out of the holes
Note that the green wire is attached to the frame of the element and the red wire to the core of the element.
The other side of the element may have two white wires
Disconnect all these wires, maybe using a pliers.
You can check this element with a simply multimeter, buy a new element and refit opposite to removal
Posted on Oct 03, 2010
Replace fuse in an old Westinghouse 229 fan-forced oven.
Not sure, but if you're lucky the stove will have a schematic inside. Take the back off, see if one is glued to the back or in an envelope. If back is 2 pieces try top behind controls first. Unplug 1st!
Mar 14, 2014 | Dryers
To replace element in westinghouse fan forced oven.do i need to remove oven from wall
Usually the convection element is inside of the fan housing on the back wall of the oven. If it isn't there reply with exact model# and i'll look at the parts breakdown and see where it is on your model
Gene
Jul 31, 2011 | Kitchen Ranges
Can i change the element myself on a Westinghouse avondale? Dave
unplug oven and unscrew element from inside oven...pull out of rear of stove...if having problem bring out..the rear panel behind oven can come off to help you...remove wires going to element and re-install on new element and put together
Jan 21, 2011 | Ovens
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
May 16, 2010 | Ovens
I have a Westinghouse Freestyle, fan forced oven Model NO 688.
I need a manufacturer name and model number
May 15, 2009 | Ovens
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
What is the difference in kw rating between a westinghouse 660 to a westinghouse pop663s
Just tried to look up the model # and couldnt find it. Usually the difference in kw rating , if there is a large difference , normally has to do with weather it is self cleaning model, how quickly the oven pre heats if it has a pre heat mode, how quickly the burners heat up and how hot they get. If you need more specific answers on those models please recheck model #'s and I will try finding them again and see what the difference is and why.
Nov 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
680 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
