Question about Yamaha RX-V990 Receiver
Blinking light on volume knob and no sound output. it turns on o.k.
5 Suggested Answers
SOURCE: blinking light on volume control
yup, its just the remote control that has muted the system.
just press mute on the remote, and it should work.
Posted on Dec 30, 2007
Coldcut
  • 1554 Answers
SOURCE: Volume light blinking, no sound.
Plug in some headphones as they are usually always active and see if you get any sound and volume control of them.
if not the switches may be stuck .
or the output fuses blown.
it gets sticky to work inside one of these without electronics experience and you can do more damage.
The fuses are about all you are allowed to fix.
Posted on Jan 31, 2008
SOURCE: volume knob blinking
hit the mute button.
Posted on Jul 11, 2008
  • 33 Answers
SOURCE: no sound, volume knob is blinking
On the bottom of the remote on right side, right next to the master volume - key . it is actually called muting instead of just mute. Hope this helps.
Posted on May 05, 2009
Is there a way to adjust the speaker output volume on a Dennon av 800 without the remote
If you look to the right of the receiver there is a knob that says master volume. Turn the knob in order to change the volume. It shouldn't matter what sound mode you are in.
Jul 05, 2016 | Audio Players & Recorders
Volume not function.
You need to be a bit clearer on the exact nature of the issue.
Please include if the unit was working and suddenly stopped producing sound (ie - speaker output fuse blew) or if you relocated the unit, and after hooking it back up, you aren't getting any sound (ie - not hooked up right) or if the volume knob isn't changing the readout for the volume level (logic or knob broken) - and also include the make and model of WHAT the volume knob is attached to (ie - Yamaha receiver model X)
Feb 22, 2011 | JVC Audio Players & Recorders
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
Why do the volume numbers on old receivers start
This type of calibartion is known as a logarithmic scale.
The numbers refer to decibels below the maximum output of the amplifier section of the reciever, or decibels of attenuation (making smaller/quieter).
Without going through logarithim theorey, the logarithim (base 10) of 1 is 0. So if 1 is the maximum output of the amp, as you turn the knob down from maximum you are adding more and more attentuation to the output (relative to maximum) and so the loudness of what you hear goes down, even though the number on the scale is going up !
Most peolpe associate decibels with sound levels, but anything can be measured in decibels, so long as there is soemthing to reference it against.
Nov 04, 2009 | Pioneer VSX-D409
The fault lights are blinking. No audio
If the amp is going into protect without audio passing it could very well be an internal short. In this case audio typically won't pass at line level. Have you tried turning the input gain stage knobs all the way down as well as the source material and slowly creep the volumes up? If it takes some audio before it faults you may want to double check the load you are placing on the amp's outputs. I'm assuming at this point it doesn't matter what speakers you are hooking it up too, it still crashed on you. Remember that Audio can be measured in voltage as well so you can measure the outputs of the amp with a volt-ohm meter.
Sep 18, 2009 | Crown CE1000 2-Channel Amplifier
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
Jan 05, 2008 | Yamaha RX-V992
Yamaha RX-V990 Receiver Logo
123 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
