Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
The manual converge is all unaligned and I can't get it back together and now I can't watch tv without seeing all colors
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Need to repair the comvergence ic , and maybe replace 2 resistor , this repair is about $250 , i would recomend u to hire a tv tech for this job , because after they replace the ic they may has to do some aligments
Posted on Aug 26, 2010
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Blue lines will not line up
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 16, 2009 | Hitachi 57SWX20B 57" Rear Projection...
PROJECTORS UNALIGNED(SONY)
Not sure what your asking here?
Marc Engineer
Mar 24, 2009 | Panasonic CT-20G22 20" TV
RGB lamps are not aligned
2c07611.pngSolution
  • Screen looks 3D
Jan 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Colors not aligned
convergence circuit. prob. need tech
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
PHILIPS MODEL # 46PP93 0217 40 INCH.
It may be the fluid in the CRT or the convergence chips are bad.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 22, 2008 | Philips 51PP9100D 51 in. Television
Looks like watching 3D movie(colors) and rounded
This is a convergence problem and is either bad connections on the convergence ICs or defective ICs. If you feel that you can solder, you should be able to repair this yourself. First try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These ICs are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Toshiba 57HDX82 57" Rear Projection HDTV
convergence IC.s replacement and realigment job for expert technician no to expensive job
Apr 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
