Can't print and can't scan or copy LCD display ( jam 1 ) or ( no cartridge )
  • 724 Answers
Usually when a jam occurs there can not be any functional traffic.
Disconnect data or printer connection cable and the power cord.
Open all access panels doors etc reseat all removable parts. Plug the power cord back in the printer and power it up see what happens. If clear then connect the the data line printer cord
Posted on Aug 26, 2010
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
How do you reset a replace toner error on brother printer
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Apr 07, 2014 | Brother MFC-7860DW - Laser Multifunction...
Jam in top 3015d
Sir/Madam
Occasionally, media becomes jammed during a print job. An error in the software program and a jam message on the printer control panel display indicate a media jam. To prevent a jam, see the following instructions:
  • Only print on media that meets HP specifications.
  • Only print on media that is not wrinkled, folded, or damaged.
  • Make sure that the printer is clean.
  • Make sure that the input trays are loaded properly and are not too full. See the start guide for more information about loading input trays.
When adding new media, always remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, which reduces media jams
Clearing a media jam
CAUTION: Media jams might result in loose toner on the page. Use cold water to wash toner off of clothes, as hot water will permanently set the toner into fabric. To remove toner from hands, wash hands in cold water.
CAUTION: Do not use a sharp object, such as a pencil or scissors, to remove jammed media.
NOTE: When clearing jams, including jams in the output bin, always push the print-cartridge-door release to open the top cover, and remove the print cartridge. Keep the top cover open and the cartridge out until the jam has been cleared. Opening the top cover and removing the print cartridge relieves tension on the printer rollers, which makes removing jammed pages easier.
Push the print-cartridge-door release and open the top cover.
Figure 1: Pushing release and opening top cover
Grasp the handle of the print cartridge and remove it. Set it aside.
Figure 2: Removing print cartridge
CAUTION: To prevent damage to the print cartridge, do not expose it to light any longer than necessary. Place the print cartridge in a paper bag or other opaque container until it can be placed back in the printer.
With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the device.
Figure 3: Jammed media most visible
When the jammed media is removed from this area, replace the print cartridge.
Figure 4: Replacing printer cartridge
Press the supporting springs, and close the top cover.
Open the media input tray and remove any media from the tray.
Slide the media guides inward as far as they will go. Press and hold down the tabs inside the media input tray, and slide the media input tray out of the printer.
Figure 6: Removing media input tray
Replace the input tray into the device.
Figure 7: Replacing input tray
After clearing the media jam, it may be necessary to shut down the printer, and then turn it on again.
NOTE: To add new media, remove all of the media from the input tray, straighten the stack of media after adding the new media, and then place the stack in the tray.
Clearing other media jams
If the media has jammed where it exits the printer, grasp the leading edge of the media and pull the media out through the output bin.
Figure 8: Removing jammed media from output bin
NOTE: If the printer is shut off before clearing the media jam, turn it on again, and then restart the printing or copying job.
Tips to avoid media jams
Make sure the automatic document feeder (ADF) media lever is in the correct position for the media being used. Slide it to the single-sheet setting (to the right) when scanning on thick media. Slide it to the multiple-sheet setting (to the left) when scanning on regular media.
Make sure that the input tray is not overfilled. The input tray capacity varies depending on the type of print media that is used.
Check that the input tray is securely in place.
Do not add print media into the input tray while the printer is printing.
Use only HP-recommended media types.
Do not let print media stack up in the output bin. The print media type and the amount of toner used affect the output bin capacity.
Check the power connection. Make sure that the power cord is firmly connected to both the device and the power supply box. Plug the power cord into a grounded AC power outlet.
Media jams occur in the automatic document feeder (ADF)
Occasionally, media becomes jammed during a copy, scan, or fax job.
A software error message indicates a media jam, and the Doc feeder jam Clear, Reload message appears on the printer control panel display to indicate a jam.
  • The ADF input tray is loaded incorrectly or is too full.
  • The media does not meet HP specifications.
Typical automatic document feeder (ADF) jam locations Input tray areas: If the page is sticking out of the input tray, try to remove it gently from the input tray without tearing the page.
Figure 9: Removing jammed media from input tray
Output paths: If the page is sticking out of the output bin, try to remove it gently without tearing the page.
Figure 10: Removing jammed media from output bin
  • Intermediate location: If the page is sticking out of the input tray and into the output area, see "To clear a media jam from the automatic document feeder (ADF)" below for instructions.
Automatic document feeder (ADF) media lever If a thick media is being used, slide the media lever to the single-sheet setting (to the right). Load a single sheet of media into the ADF.
When the copying, scanning, or faxing jobs are complete, slide the ADF media lever back to the multiple-sheet setting (to the left).
Clearing a media jam from the automatic document feeder (ADF)
  1. Using both hands, pull the printer control panel door toward you.
    Figure 11: Opening printer control panel door.
  1. Remove any jammed media. Figure 12: Removing media
NOTE: Use only your hands to remove jammed media. Using other objects can damage internal parts.
Make sure that all of the pieces of media are removed, and then close the printer control panel door.
Figure 13: Closing printer control panel door
I Hope Your HP Printer Problem Resolved By Now,In Case You still Having HP Printer Problem Then Visit Official HP Printer Website Below Link URL:
HP Printer Issue:
HP Support document HP Support Center
Or
If You still need HP Printer assistance Then Follow Us On :
HP Printer Support
Feb 13, 2014 | HP LaserJet Enterprise P3015d BW laser...
How do i replace the ink on my canon mx340
These are the steps originally from the http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340#ServiceAndSupport
Install the FINE Cartridges
1. Lift the Scanning Unit (Cover) (A) and fix it with the Scanning Unit Support (D).
Close the Document Cover (E) and lift it with the Scanning Unit (Cover).
important:
  • Do not touch the buttons or LCD (F) on the Operation Panel (G). May result in unintended operation.
  • When opening the Scanning Unit (Cover), the FINE Cartridge Holder moves automatically.
  • If the FINE Cartridge Holder does not move, make sure that the machine is turned on.
  • If the Scanning Unit (Cover) is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
2. Make sure that the FINE Cartridge Holder (H) moves to the installation position.
3. Follow the next procedure to insert the Black g0070683.png and Color g0070684.png FINE Cartridges into their corresponding slots g0070683.png and g0070684.png.
4. Open the Ink Cartridge Locking Cover g0070683.png on the right side.
Pinch (I) firmly and pull up the cover.
5. Remove the Black FINE Cartridge g0070683.png from its package.
important:
  • Handle the FINE Cartridges carefully. Do not drop or apply excessive pressure to them.
  • Be sure to use the supplied FINE Cartridges.
  • Be careful not to stain your hands or surrounding work area with ink on the removed protective tape.
  • Do not touch the Electrical Contacts (K) or Print Head Nozzles (L) on a FINE Cartridge. The machine may not print properly if you touch them.
6. Pull the orange protective tape (J) in the direction of the arrow and remove it carefully.
7. Place the Black FINE Cartridge g0070683.png into the right slot g0070683.png.
important:
  • Do not knock the FINE Cartridge against the sides of the holder.
  • Install in a well-lit environment.
  • Install the Black FINE Cartridge g0070683.png into the right slot g0070683.png, and the Color FINE Cartridge g0070684.png into the left slot g0070684.png.
8. Push down g0070683.png of the Ink Cartridge Locking Cover until you hear a click to close it completely.
View the Ink Cartridge Locking Cover g0070683.png straight on and check that it is locked correctly (not at an angle).
9. Insert the Color FINE Cartridge g0070684.png into the left FINE Cartridge Holder g0070684.png in the same way as the Black FINE Cartridge.
10. Lift the Scanning Unit (Cover) slightly (1) and fold the Scanning Unit Support (2), then gently close the Scanning Unit (Cover) (3).
important: Do not touch the buttons or LCD on the Operation Panel. May result in unintended operation.
11. Make sure that the LCD changes as shown in the illustration and go to the next step.
  • It takes about 1 - 2 minutes before the LCD changes.
important:
  • Once you have installed the FINE Cartridges, do not remove them unnecessarily.
  • If an error message is displayed on the LCD, make sure that the FINE Cartridges are correctly installed.
note: The LCD will turn off if the machine is not operated for about 5 minutes. To restore the display, press any button except the ON button.
Aug 12, 2010 | Canon PIXMA MX310 All-In-One Printer
The printer will not scan or print properly. An
E represents error
so make sure you try some resets like
disconnecting all the cables from the printer and keep the printer idle for sometime
so there could be issues on the cartridge or on the hardware of the printer so
check the cartridges
if empty (replace them )
if dirty clean them with a clean cloth
then check whether if there's paper jam or carridge jam
if so try to remove the jam
remove the jammed paper from the back of theprinter
Mar 30, 2010 | HP PSC 1510 All-In-One InkJet Printer
Right cartridge incorrect appears in the display after a paper jam. Will not copy or print.
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 13, 2009 | HP PSC 2210 All-In-One InkJet Printer
Cartridge jammed
So here it goes: Open the cover as if you would change the cartridge. Then press the little black button I highlighted in the picture. Keep it pressed, push “copy” on the left and then the (print) black button on the right of the lcd. The printer will somehow work and work. Wait until it rests again. Then close the cover and press the black button again. Now it should copy… and print, and so on.
Jan 04, 2009 | Canon PIXMA® MP530 All-In-One Printer
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
15 people viewed this question
k24674
