Question about Cell Phones
Naktel a200 no charging - Cell Phones
Tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Jan 02, 2013 | Acer Iconia Tab A200 Series Tablet with...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My china nktel 2008 set is mic problem i want to circuit diagram & mobile diagram
naktel 2008 mic ok but it not warking plz aolution now?????
Dec 08, 2010 | Health & Beauty
My china mobile nktel A200 not reading memory card
naktel a200 memory card not supported solve this problim
Sep 18, 2010 | Cell Phones
I have a three Y/O Toshiba A200 and the battery
You more than likely need a New Battery. Before you buy a new one, I suggest that you check the Battery Recall List on your Laptops Manufacturer's Website. If it is a Recall Item, they will replace it for free. Lucky4lynn2 :) please rate me, ok?
Mar 11, 2010 | Toshiba Satellite A200-0ET00X Notebook
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
