Question about Samsung WF328AAW Front Load Washer
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
  • 122 Answers
Remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Posted on Aug 26, 2010
    New Friend:
Nothing happens when the washer is plugged into the electrical outlet
Posted on Mar 31, 2013
Samsung washer model#wf306law/xaa error code tE - temperature sensor problem. what part do i need
This could be either a sensor or a wiring issue, You need to check the wiring that runs from the sensor to the electronics, the wires can break inside the plastic sleeve and cause the electronics to think there is a sensor fault, It could be a sensor fault but i usually find a broken wire in these machines.
May 10, 2017 | Samsung Washing Machines
Recall numbers for WF306LAW/XAA WASHERS
Sorry we do not have this information at this website.
Apr 19, 2017 | Washing Machines
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
My WF306LAW-XAA Samsung washer will not stop filling with water and hence will not advance to wash cycle. Do you think it needs a new mixer valve?
No, you have a water level switch problem. Simple solution is to pull the hose from the water level switch and blow into the hose to clear out the debris. DO NOT BLOW INTO THE WATER LEVEL SWITCH!!! It will break!!! Replace the hose back onto the water level switch and it should work fine. Good luck
Jun 17, 2011 | Samsung Washing Machines
Not washing properly, smells like mold
I have a samsung WF306LAW/XAA and it also smells like mold. I found I had a small leak which turned into a large on over a long periond of time. The leak was in the guide water also known as the silver care kit. The bottom of the washer has foam wire and hose covers to soften the noise, they get wet and mildew. make sure you do't have a small leak and dry out the cavity.
Jul 28, 2010 | Kenmore Washing Machines
Samsung Washer WF306LAW stopped draining and won;t spin
Drained the water from the tub into a bucket. Since the water flowed through the disharge tub I knew there were no obstructions in the line. I then took took the discharge pump out and took it apart. Turned out to be a bobby pin in the motor that was jamming the impeller.
Put it all back together and it works just fine. Took me about 2 1/2 hours total to diagnose and repair.
Aug 30, 2008 | Washing Machines
Samsung WF328AAW Front Load Washer Logo
526 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
