Question about EnGenius Computers & Internet
I have an AT&T 2wire router. I cannot get my ERB9250 wireless range extender to connect.
  • 1 more comment
  • d_whatley258 Aug 27, 2010
    I followed the setup guide provide by EnGenius to no avail. I tried your suggestion of powering off both the router and extender for 30 secs. Still says unsuccessful connection!
    I tried using my laptop to connect...got the same response unsuccesful connect to the 2wire254.
    Do you think it might be a compatibility problem between the EnGenius ERB9250 and the AT
    I discovered what the problem was. I had failed to set the WEP security correctly. The unit is now functioning as it should.
    President:
  • 1,566 Answers
Hello there,
What have you done so far to troubleshoot the problem?
Posted on Aug 27, 2010
  • 3,083 Answers
Try to verify it on another computer (friend's laptop, etc.). If it works then, you'll know you have a software conflict or problem on your computer. Otherwise, you'll have to go in to Network Connections and see if it's recognized, etc. There's really no way one can troubleshoot extenders, other than trying them on more than one machine, and eliminating them by that method. I do know that on some hardware, you have to install the CD first, before you connect the hardware, or it just won't work. That might require uninstalling it, and redoing the process.
Anyway, good luck, and hope this helps.
  • EnGenius Master
  • 6,487 Answers
In configuring the range extender to work with your wireless router make sure that you have all the wireless settings of your router because you need to input it to your extender settings, then once you're done with that power off the router and the extender for about 30 seconds to sync them and then check if its working fine now.
Posted on Aug 26, 2010
  • Mark Gil
    Mark Gil Aug 27, 2010
    It seems that this is a compatibility issue between the router and the extender that you have since you have all the correct settings on both of them, but just to make sure do a firmware upgrade on your router and if still wont work the 2 device are not compatible.
  • Mark Gil
    OK good happy to hear that just a WEP settings problem,
EnGenius ERB9250 setup for mac
You can do it from your web broswer if you know the IP address and it's plugged in.
Sep 19, 2013 | EnGenius ERB9250 300Mbps Wireless N Range...
Lost setup disc download
You don't need a disk. You can set it up from your web browser, something like http://192.168.1.2/
http://www.engeniustech.com/resources/ERB9250%20Quick-Start%20Guide%20_Oct%207%202010%20release.pdf
Sep 15, 2013 | EnGenius ERB9250 300Mbps Wireless N Range...
How to open erb9250
Just unscrew it from the bottom to take a look-see!
Jan 22, 2013 | EnGenius ERB9250 300Mbps Wireless N Range...
Unable to enter the extender's setup (configuration) pages anymore. Tried resetting the extender; repairing the local area connection; tried accessing the extender through its ethernet port....
How to reset the device?
Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
Oct 14, 2011 | EnGenius ERB9250 300Mbps Wireless N Range...
Ineed setting of EnGenius ERB9250 300Mbps Wireless N Range Extender
Hello, here is the manual for the ERB9250: http://www.engeniustech.com/resources/manual_ERB9250.pdf It will show you how to access all of the settings you need.
Mar 05, 2011 | EnGenius ERB9250 300Mbps Wireless N Range...
Is it possible to set up the Engenius 300Mbps Wireless N Range Extender with an AT&T 2wire 3800HGV-B wireless router/modem? Router does not have a WPS button.
Yes you can. The button is in the software. goto http://192.168.1.254 or whatever the URL for the modem. Login. Goto Home-->Wireless--> Push WPS Button Remotely and push the button. I don't know if you need to have the repeater nearby when you do this. I had mine sitting right next to my router.
Feb 01, 2010 | 2wire Computers & Internet
2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
Apr 04, 2009 | 2wire 2700HG-B Router (2700HGB)
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
Computers & Internet Logo
623 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
