Question about LG WM-2277HW Front Load Washer
I have a LG tromm model # WM23277HW front loader. The door arm is bent and doesn’t close properly and now leaks. How do I order and replace that part on the machine?
dutchman05
  • 487 Answers
SOURCE: I have a LG tromm
Here is your SERVICE MANUAL
Posted on Jun 23, 2008
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
SOURCE: I have LG TROMM WM1812CW soap leaks out from
For the owners manual go to
http://www.lge.com/us/appliances/washers/index.jsp
and search for your owners manual by part #
Posted on Nov 21, 2009
  • 343 Answers
SOURCE: how do i clean the filter on an LG Tromm front
The pump filter is accessed via the small hatch at floor level. It can also be behind the kick plate..Unscrew the filter and clean. It may be very badly clogged with whatever is left in pockets. Remember when the filter is removed the water will drain out..Also, check that coins haven't jammed the impeller. Leaning the machine back against the wall will stop the last of the water from draining and will allow better visual inspection...Good luck...Nomess
Posted on Apr 24, 2010
SOURCE: what does oe mean on the front loader lg tromm and
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Posted on Jun 12, 2010
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Maytag MTW5770 TQ model. 3 years old. You have to drop the lid hard or push on it to get the machine to recognize the lid is 'closed' and can then start the agitation and rest of cycles. It does...
Some of them have a mercury switch that has been bent so it doesn"t make good contact with the liquid mercury. If you can find it you can bend it back. It has to be on the door or an arm under the door or door hinge.
If you know how, you can raise the washer top using a flat knife type of tool to move springs thru the gap between the washer top & the lower front piece. (assuming it's a top loader)
In a front loader it's still near the door.
Jun 26, 2011 | Maytag MTW5770TQ Washer
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
Error Message: Fuser door open
You have to look on the sides of the printer where the door closes. Here it should be a mechanical sensor. Make sure that it closes properly to sense the door is closed. If it doesn't, it needs to be replaced. More exactly, it's a sensor underneath the fuser door activated by a plastic arm, which is difficult to see. This sensor has a spring arm against which the plastic arm pushes and you have to bent the spring arm out just for a second so that the sensor can activate by itself.
I hope I helped you!
May 19, 2011 | Office Equipment & Supplies
My LG washing machine model Tromm front loader not working properly.If we set time for 1hour 30 minutes it is not running after 43rd minutes or SO.If timer problem,what to do.Advise please
Usually there is a timer relay that is in there that needs to be replaced ,check that out its a big cube looking thing with four or five prongs on the bottom for contactors
Mar 28, 2011 | LG WM-2277HW Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water leaking from the door and door will not unlock after washing
i just placed my order @ home depot for the LG TROMM front loader washer. i purchessed the 5 yr warrenty and i belive after reading some of the comments in here that this was a good move. I used a maytag neptune @ work and it was a peice of JUNK! it has the mildue smell everyone is talking about. i was told of a remidy for this smelly issue. pour a good amount of casscade dishwasher POWDER not liquid into the washer drum and then pour bleach into the wash slot on the fron loader and then put the washer on the longest setting and let the machine run the cycle. i hope this works for you. i will try it once a month om my front laoder when its delivered. GOOD LUCK!!!!
Nov 29, 2007 | LG WM-2277HW Front Load Washer
"Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Aug 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
49 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
