Question about Nokia 2626 Mobile Phone
NOKIA 2626 1-2 MINTE AFTER AUTO RESTART SOLUTION P/S
Nokia 2626 no signal
Hi, Switch off your phone and remove your sim card ,and after 10 minutes insert your sim card and restart your phone, if the problem still persist , restore it by selecting "Restore Setting Only" from >Setting>> Restore Factory Setting.Otherwise contact mobile repairing shop.Thanks for visiting fixya
Aug 17, 2011 | Nokia 2626 Mobile Phone
Pa jumper pin no of nokia2626
Nokia 2626 Signal No Network repairing solution.Nokia 2626 Signal No Network Mobile Repair diagram pictures Service Tips and Tricks.Make Jumpers as shown in diagram or replace the shown components .
How to short Nokia 2626 PA.jumper Pa nokia 2626. here is a diagram that is showing how to jumper and short P.A of nokia 2626. it is used to check that mobile is getting signals or not. if signals are to low with jumper change the P.A
Jan 21, 2011 | Nokia 2626 Mobile Phone
NOKIA 2626 displays "PHONE RESTRICTED".
sir plz help nokia 2626 phone ..display phone restricted
Dec 22, 2010 | Nokia 2626 Mobile Phone
Nokia 2626 me seting save nahi ho rahi
Phone ko factory restore karo.
Follow the steps :
Press "Menu" > "Settings" and locate "Restore Factory", select it and enter "12345" as code when you are asked, confirm if you are prompted and check if it does help or not. Once it's done, restart your phone if it doesn't restart itself.
If you need further help, let me know.
good luck.
Thanks for using FixYa.
Nov 26, 2010 | Nokia 2626 Mobile Phone
Please help me to unlock my Nokia 2626 IMEI : 352029021519528 thank's for your attentions..
There are many methods for unlocking mobile phones, but codes are best one, because it is easy and safe also...
For the best unlock code for your Nokia 2626 model mobile, visit this site http://www.mobileunlocksolutions.com/nokia-2626/rs1wp9/
It has the step by step instructions and easy methods for unlocking your Nokia mobile phones.........
Sep 01, 2010 | Nokia 2626 Mobile Phone
How to restart nokia 2626
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens.nokia 2626 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - nokia 2626 mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent nokia 2626 from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling nokia 2626 phone memory.
Cause 3 - Memory Cards - Some people have reported that nokia 2626 restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their nokia 2626 mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your nokia 2626 phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this
Good luck
Jul 09, 2010 | Nokia 2626 Mobile Phone
2626 Mobile Phone: When someone call me on my nokia 2626, I can see t...
When someone call me on my nokia 2626 I can see that someone is calling me but I can't hear ringtone.
May 18, 2010 | Nokia 2626 Mobile Phone
How do I get radio on a 2626
CONNECT YEAR PHONE AND YOU LISTEN RADIO IN NOKIA 2626. 2626 HAVE A RADIO SOFTWARE FACILITY
Sep 26, 2009 | Nokia 2626 Mobile Phone
I forgot my phone Nokia 2626 security code... Please, help..
Master reset code is 3774446235
rate this solution fixya.
Cheers.
Aug 16, 2009 | Nokia 2626 Mobile Phone
I want nokia 2626 cable drivers for pc connect
here's the software link:
http://www.topshareware.com/free-nokia-2626-pc-suite/downloads/1.htm
just download and install then restart PC and connect phone. have fun :)
Jan 03, 2009 | Computers & Internet
Nokia 2626 Mobile Phone Logo
178 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
