Question about Bryant Heating & Cooling
My coil is all rusted out, i understand there may be a recall on my unit model number fb4anfo36 is this true? t
    Master:
  • 571 Answers
Highly unlikely, I would just get a few prices on replacing and get it done. Hard to prove a factory defect & most warranties are on moving parts & electrical.
Posted on Dec 06, 2013
2 Suggested Answers
  • 383 Answers
SOURCE: I HAVE A RADCO #FB4ANFO36,,
Apparently not-
I did a search for this model, and there is NOTHING on the internet about it!
You could probably tell, by looking at the name-plate information-
If there were heaters-- the name plate data should say both the amps and the watts of any elelctrical load. (And by the way-- that would take a bigger service to it, too!)
So-- Did you get the air bled out of the oil feeding the Oil burner pump yet?
Mack B
Posted on Jan 18, 2011
Is there a recall on Frigidaire dehumidifier Model FAD504DUD
Some dehumidifiers with the model number, FAD504DUD, are subject to a recall. Record the serial number and then go to https://www.recallrtr.com/dehumidifier to check if your unit was manufactured in the bad batch.
Without the serial number, I can't be sure if your unit is in the 2016 recall. For details, you can look at https://www.cpsc.gov/Recalls/2017/Dehumidifiers-Made-by-Midea-Recalled .
I hope this helps.
Jan 26, 2017 | Frigidaire Dehumidifiers
Snopes truth fiction
As mythbusters would say : Plausible.
Garmin's use Lithium Ion battery technology which can explode and catch fire. Garmin issued an older series of devices a Battery Recall because of some reported instances call their support number and they can tell you if your Garmin serial number has been recalled. Understand though that it is a battery issue and many companies have dealt with exploding batteries. Try reading this for more info.
Why lithium batteries keep catching fire
Jul 19, 2014 | Garmin GPS
Filter queen power nozzle recall
you mus call them, and explain your sense, and they will accept your comments, and proceed according your will. Do it, Do not waste your time.
God bless you
Jul 23, 2012 | Filter Queen Majestic Canister Vacuum
A physical inspection report came up with, this unit could be on recall? Is that true?
Most companies do not recall entire furnace. Last time that happened was in the 80s. I would need the serial number to check for up dates but that model has not had any major problems.
Sep 08, 2011 | Goodman GMS90703BXA Heater
The drip pan in my Blue Ember grill has rusted. The model number FG50069. My understanding is this is a recalled part. I've tried calling the 800-396-3838 number a few times but remained on hold for a...
Unfortunately, you may have to put your grilling on hold, for a bit. The drip pan is considered a body part and is not stocked by any of the independent grill parts stores. They only stock the internal workings of the grill, from burners to valves, to cooking grates, ignitors, etc.
Currently, Fiesta's website is down for construction. But, when comes back up, you can probably order the drip pan online, rather than get a free one, due to the safety recall.
Apr 26, 2011 | Fiesta Blue Ember Gas Grill
I HAVE A RADCO #FB4ANFO36,, UNIT IS BLOWING BUT THERE IS NO HEAT. IS THERE A HEATING ELEMENT IN THESE UNITS?
Apparently not-
Mack B
Jan 18, 2011 | Heating & Cooling
Have model #FG50057- my bottom of my grill is all rusted out, even the slots it slips into are rusted, can this be fix
May be one of the models (FG50045, FG50057, FG50069) which is on recall. Blue Ember (Fiesta) will send you a new stainless steel drip pan along with a replacement hose. Here's a list of serial numbers qualifying for the recall. Blue Ember's phone is 1-800-396-3838
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09283.html
That might take care of the drip pan (presuming that is the "bottom" that you are referring to), but it sure doesn't solve the problem of the rusted slots. You may be SOL but could try to cut some little aluminum angles and screw it into the sides if there is any bearing metal left.
Feb 10, 2010 | Fiesta Blue Ember Gas Grill
Need replacement grease pan for a Fiesta Blue Ember
Oct 16, 2009 | Fiesta Blue Ember Gas Grill
2000 nissan frontier crew cab gas tank
there may be a recall on the sending unit, but the VIN # needs to be checked by the local Nissan dealer to see if the campaign applies to this truck. Tha campaign is for the fuel pump sending unit, not the gas tank, however in some cases, where the sending unit bolts brake, dealer will have to put a new gast tank into it. it also corrodes on top, where the sending unit seals the gas tank and it turns on the check engine light for a evap small leak, bacause the sending unit is not sealing properly, bacuse of all the rust build up on top of the tank. Good luck.post result.
Aug 16, 2008 | 2001 Nissan Frontier Crew Cab
Heating & Cooling Logo
44 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
