Question about Fedders A6X05F2D Air Conditioner
My fedders a/c will turn on fine but after some minutes the fan will stop but the compresor will still work. i will haveto turn it off and turn it on again after 10 minutes and it will work fine again. but it will stop again.
    Novelist:
    Champion:
  • 266 Answers
You need to replace you fan motor. It is going bad and the amount of amps to keep it going is causing it to over heat. The next time you try it and the motor kicks off see if the motor frame is hot. Be careful I have seen the hot enough to cook eggs. These motors can run between 68 dollars and 160 dollars. The age of the unit and your ability to replace the motor dictates a repair or a replacement. If you ck on the price of the motor and want to do it your self I will be happy to walk you thru it. good luck
Posted on Aug 26, 2010
I have a fedders window ac unit 110 model A6X06F2A works fine for about 10 mins the the fan stops
i would try to oil bearings on motor. that failing replace run capacitor. motor must be getting hot.
Aug 01, 2015 | Fedders Heating & Cooling
The Fedders window unit A/C is making chirpy bird noises when it is first turned on for about 20 min. or so. What is the cause?
Usually a dry bearing somewhere. You need to fix it. If it is in the compressor rather than the fan, it is probably uneconomical to repair. It is better if the chirping STOPS after 20 minutes rather than STARTING after 20 minutes. Heat and use is fixing the problem for you.
May 18, 2015 | Fedders Heating & Cooling
Purchased a fedders a/c 18000 unit still under warranty. called the 800# they said company had filed bankruptcy and were not responsible for repairs. 350$ mistake. Fan runs too slow for unit to kick in....
Check the capacitor for the fan motor. You can do that with a multimeter with the capacitor test function or if the capacitor looks swollen then it is probably bad. Also, make sure the fan rotates freely by hand. Let me know if you need more help.
Jun 08, 2010 | Fedders 12,000/10,200 BTU Heat/Cool Room...
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Ac fedders portable
Im not sure I understand the problem. Your AC runs about 4 minutes then the compressor stops and the fan stops as well? What is the model of the air conditioner?
Jun 29, 2009 | Coleman Mach III Air Conditioner
Old 1972 Fedders centeral air fan will not always come
Since its a 1972 its probably called a fan center---------combination fan relay and transformer and they are still available.
Jun 14, 2009 | Fedders A6X05F2D Air Conditioner
Fan works for about ten minutes then begins to slow down
Try spraying some WD-40 or similar on the motor shaft. There is probably some buildup of contaminents gumming up the bearings.
If I knew what country you lived in, I might be able to tell you where you can buy the motor if you need it.
May 29, 2008 | Fedders X Chassis A3X05F2B Air Conditioner
Fedders A6X05F2D Air Conditioner Logo
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
