Question about Roper RT21AKXKQ Top Freezer Refrigerator
Ice maker makes no ices. I check ice maker water valve directly to 110 volts and it is opening.
  • Roper Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
My ice maker doesn't produce ice reliably.
Do you have a filter in the refrig. It may be clodded
Feb 08, 2015 | Refrigerators
Ice maker stopped working
run service test with volt meter hooked up to the two terminals on water valve if you get a 110 volts to water valve when it is called for and water valve dose not open then the valve is bad. make sure the water valve screen in the end of it is not stopped up.
Jun 19, 2013 | Kitchen Appliances - Others
Ice maker on amana abc2037dtb is not making ice, but water dispenser works
you could still have a bad water valve. there are 2 ports. i usually jump the ice maker thru a cycle and see if you get 110 volts to the ice maker water valve. if you get a reading the water valve is bad. if there is no reading then the IM head is bad. last and not least, the IM head needs to be pulled down, see if there is a build up of ice in the supply tube to the IM. then you have a problem with the board
May 14, 2012 | Amana Refrigerators
Water will not go to ice maker
It's most likely a bad water valve. If the valve is good, you will have a bad micro switch inside the ice maker head or a bad motor. You can check the water valve by connecting 110 volts to it. First disconnect the power plug and the water line opposite where the supply from the house connects from the water valve. Connect 110 volts (Just for a second) to where the plug was attached. If water does not squirt out, its a bad valve. Good luck.
Dec 15, 2009 | Kenmore Refrigerators
Kitchenaid refrigeratorice make no water
When the ice maker stops to fill with water ,check if the solenoid (dual valve) gets power (110 volts) ,if it does and won't open you have to replace it ,but if it doesn't get any power ,the problem is the ice maker itself.
Sep 04, 2009 | Refrigerators
My regerator is not making ice . It model # ed5chqxkq03 dual door. What could it be? I normally hear the water valve being open. I no longer hear this sound,
either the water valve is bad or the ice maker is bad.... only way to tell which is bad is 1. jump the water valve with 110 volts or advance the ice maker and check for 110 volts at the water valve you will have to sit there a while doing that
Jun 26, 2009 | Whirlpool Refrigerators
The ice maker works, I poored water directly to the ice maker and it works, don't understand what you mean with alligator clips, should i just take the hose leading to ice maker off, the intake water valve...
Wrong! ok what it is you have a double water valve. 1 valve goes to the ice maker and one goes to the water dispensor. what you need to do is take the valve that goes to the ice maker by tracing the water line from ice maker to the valve and jump it direct with 110 volts. if you get water by doing that the ice maker is bad if you dont get no water that way it will be the water valve
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
No water to ice maker
Check for frozen line between ice maker and water valve, jump the water valve direct with 110 see if you get water if not then buy a new water valve if so then buy a new ice maker...whirlpoolpartssurplus.com
Jun 24, 2009 | Refrigerators
Ice maker not working water working
somtimes the line to the ice maker frezes.you could test by putting 110 volts to the water valve direct[or inspect]water should then enter ice maker .your post dosent say your brand but most ice makers you can start by pulling on the harvest rake till starts.[mechanical only] if water valve good and line not frozen .then could be loss of power to ice maker[check at ice maker plug in at frezer] if thats ok then ice maker has failed,replace God bless,tom
Jan 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
