Question about Magic Chef CDB6100 Built-in Dishwasher
My chef classic dishwasher is not completely cleaning the dishes. There is no obstruction to the tablet/powder door opening, although there is a small amount of powder left at the end of the cycle. Both top & bottom spray bars are clear & rotate, the water is heating & there appears to be plenty of water getting water into the machine. Drain filters are also clear.
  • Magic Chef Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a rel='nofollow' href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a rel='nofollow' href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Posted on Aug 26, 2010
The tablet is still in the dishwasher when the cycle is done the tablet door is open and there's nothing blocking it but the tablet is only half used thanking you? Maisie
If you have used the same tablets before with no problem I'd say not enough spray or not enough spray pressure now. Clear all holes in both spray arms and clean the filter or filters. If you are trying a new kind of tablet try a different one or a powder. If it is still getting your dishes clean be thankful and don't worry.
Jan 24, 2017 | Dishwashers
Tip
What to do if your Dishwasher isn't cleaning well...
Check the following when experiencing poor cleaning results:
- Dispenser (Where you put the Dishwasher Tablet or Powder)
Make sure that the flap holding the powder in is not loose.
Make sure it is dry before ever putting in powder.
- Dispenser (Flap Type)
To check if it is still opening for the Spray Arms (Spray Arms need to throw water on the Powdered contents to wash the dishes) - Put the Dishwasher in a cycle, and halfway through the cycle, open the door. if it has not opened then maybe the solenoid/actuator needs to be replaced.
- Program Selector (Not the component, the function selected)
More time consuming programs are more likely to wash more effectively, try selecting these with a higher heat setting instead of your usual programs like quick wash etc..
- Machine overloaded.
Make sure the baskets are not overloaded with dishes, mugs & glasses as this can make spray arms find it more difficult to clean between them
- Soap
In tests regarding powder vs. 3 in 1 tablets like "finish", it has been shown that powder gets dissolved much better, this is because the 3 in 1 tablets are designed to disintegrate on certain heating phases of only a select few brands of Dishwashers. So if you are unsure, or experiencing undissolved tablet - Use powdered dishwasher soap instead.
- Salt container
Refill the Salt container every 3 - 4 months depending on how frequent you use the dishwasher
- Spray arms
These can often be clogged with dirty water etc. clean these with toothpicks and pressured water.
- Filter
Clean these every time after a wash, usually found at the bottom of the dishwasher where water drains away.
- Over the counter products
These can be bought at Appliance spare outlets or even at some supermarkets. Use these as the directions indicate.
- Element (Last step if not improved)
Replacing a element is usually a last option, if no improvement was experienced by doing all of the above it could be that the element is not heating at the right temperature, or not heating at all.
Either replace this yourself (with various degrees of difficulty depending to the Make and model) or get a qualified service technician to do it with you.
Hope this helps :-)
If you found this helpful, please vote accordingly.
on May 10, 2011 | Dishwashers
My detergent is always still stuck in the dispenser. The water temp and pressure are both fine, the machine is clean as well as the spray arms, and the door opens but water just isn't dissolving it. I have...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 22, 2011 | Magic Chef 24 in. DU2500 Built-in...
ITS NOT REALLY CLEANING
I cannot tell you why your tablet doesn't clean well not knowing your machine, but having tried several types and brands (liquid, tablet, powder) I have found that the powder cleans best in my machine. Maybe it is something to do with dissolving or your water is not hot enough --possibly tablets work best in certain machines and not others. I don't have any interests behind my advice, but Cascade Complete was the one recommended to me and has become what I use exclusively. But I am willing to try others as technology develops.
May 12, 2010 | Zanussi 24 in. DA6141 Built-in Dishwasher
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Soap remains in glassed or cups, both with powder or Tablets
1st check your water temp, it needs to be between 120 and 140 to clean dishes and if temp is good then your spray arms, one or both isn't turning which mean low water pressure coming in or the wash motor is bad.
Larry
Nov 25, 2008 | Magic Chef Dishwashers
Dishwasher powder/tablet not being used
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Mar 06, 2008 | Dishwashers
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Dishwasher won't dispense soap
The dispenser's unit should be replaced. You can try as well to operate the dishwasher while putting the powder detergent or the tablet on the dishwasher's bottom and if you will get good results, to opereate the machine this way. Good luck!
Sep 05, 2007 | Roper 24 in. RUD5750DB Built-in Dishwasher
Magic Chef CDB6100 Built-in Dishwasher Logo
134 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
