Question about Sewing Machines
IDT foot bunching up fabric
I have a new Pfaff 2058 and am new to the line of Pfaffs and I am having problems with the IDT foot bunching up the fabric when I start a seam. Is it possible pilot error or should I have it looked at. Thanks
    Novelist:
  • 77 Answers
Hi Gramma Rosie,
The bunching up of fabric is due to either:
1. Obstruction in front where the fabric has to move forward (in which case you should tug a bit on the front end of the fabric as it goes ahead.)
2. The pressure foot (that pinches the fabric between the advancer teeth and itself), is either too loose or too tight. (It depends on how thick is the fabric and how many layers of fabric are you trying to pas between the IDT foot and advancer teeth) For that you need to tighten or loosen the rotary bolt on top. Its generally connected to the foot like a shock absorber having a high tension spring.
3. The fabric advancer teeth are not moving sufficiently. This you need to rectify by adjusting the up-down lever at the right that is rsponsible for fast & slow advancing of the cloth & accordingly the stitches will be longer or shorter.
I don't think it should be too much of a task for you to solve.
Good luck Rosie.
Posted on May 06, 2008
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
The presser foot on my Pfaff Tipmatic 6122 will not stay down, so the fabric will not feed.
It sounds like the pressed bar is sticking and will not push down completely and is difficult to lift. I have come across them many times on the older pfaffs. Unfortunately that is not sometime that can be fixed at home. It is caused by the lube going bad inside the pressed bar that lubbricates the spring that is inside the pressed bar. Find a pfaff dealer that knows about older pfaffs and they should be able to help.
Nov 15, 2016 | PfaFF Sewing Machines
Pfaff tipomatic 1151 sewing machine pressure foot isn't working. It will not drop own all the way to get a grip on the fabric.
This is common on older Pfaffs. The grease used in manufacturing has turned solid. It needs to be disassembled and re-lubricated.
Something a shop usually does.
Oct 18, 2014 | Sewing Machines
Idt performing poorly
for puckering the tension may be too tight
try a new needle - one for fabric and thread being used
check to make sure the feed dogs and the (what-ever) foot is being used, are working together, so the fabric moves smoothly thru
Apr 12, 2014 | PfaFF Sewing Machines
Are pfaff 1475cd sewing feet compatible with pfaff 1151 machine
Hi. Some Pfaff machines have something called an "IDT" which looks rather like a small, black walking foot behind the pressure foot, to help feed the fabric evenly. Pfaff machines with this IDT need "IDT" pressure feet. (I can't find a listing of which machines have this and which don't, so you'll have to look at your machines or check your manuals.) If both machines have the IDT, then the feet are compatible. If neither has the IDT, then the feet are also compatible.
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | PfaFF Sewing Machines
Pfaff 2048
The timing has been knocked off when it jammed. The only way to
correct this is to take it to a shop and have it retimed. This is common on these machines.
I have 25 years working on Pfaffs
Jun 30, 2009 | PfaFF Quilt & Craft Pro 7530
Sewing Machines Logo
182 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
