Question about Tasco Riflescope 3-9x50 Dwc39x50n
I got in a tight spot needing a scope last season. I was very short on cash so i bought a 3-9x 50mm cheap Tasco . I sighted it in at 100 yards. I missed the first deer . Two hours later I shot high on another deer, aimed low on the second shot and dropped the small buck in his tracks. The rifle wasn't dropped or banged up at all. Is it possible the recoil is affecting the accuracy? I shoot a Remington model 700BDL chambered in 30.06 with a 150 grain bullet. Thanks.
    President:
  • 2,702 Answers
Well one day you may lurn that cheap is cheap! and tasco is rubbish cheap! i would say without dought the cross hair in the scope has shaken apart,,,due to recoil,,,a 30-06 has a big recoil
try holding the rifle stock on your jaw and firing the rifle off?
when or if,, you wake up in hospital with a shaterd jaw and with no teeth left in it you will know then! and cheap tasco scope is an air rifle scope it cant take 2500ft/lbs of recoil???
so it wont take much of a kick to mess it up,,
i put one on a 303 enfield??? i got 3 shots before it fell to bits!
if your going to buy cheap scope's go for nicon gold crown?
Posted on Aug 28, 2010
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
www.tasco.com/pages/instruction-manuals/
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions ...www.fixya.com/.../p4821-tasco_golden_antler_3_9_x_40_mm_3_9x40Recent Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast Boolitscastboolits.gunloads.com > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
I am unable to adjust the elevation? It seems to be stuck at 10 inches below center at 100 yards and 4 inches at 50 yards on a 243 rifle. Nothing I do moves it up?
If the scope is out of adjustments and still low, you have to shim the rear base. I'd start with two thicknesses of beer can.
Sep 29, 2014 | Optics
My 3x-9x.40 scope shoots low and to the right,what does one click on elevation and wind represent?
Most scopes of this type move the bullet impact 1/4 inch at 100 yards, or 1/4 minute of angle.
Sep 19, 2010 | Tasco 3-9x40 World Class Riflescope 30/30...
HAVE A PRONGHORN TASCO MOUNTED ON SAVAGE 22 BOLT. SIGHTS IN OKAY AT 10 YARDS AND THEN IS HIGH AT 25. IS THERE AN ADJUSTMENT INTERNALLY IN SCOPE TO FIX THIS?
No, this is not a scope issue. The scope is raised above the centerline of the barrel, thus at 10 yards, the barrell is actually slightly raised in relation to the centerline of the scope in order to hit your point of aim. Since the front of the barrel is slightly inclined, at 25 yards the bullet is still rising in relation to the scope alignment. Backing up to 50 yards you will begin to see the bullet start to drop back down, at 100 yards it may drop as much as 8-10 inches, and at 200 yards, it may drop as much as 52 inches. This is assuming that you are shooting a standard velocity .22 long rifle cartridge (1050 feet per second or so).
Sep 10, 2010 | Tasco Pronghorn 3-9x50mm 30/30 Riflescope...
Moa not true past 300yds tasco 6x24x42mm
The Tasco is not a 600 yrd scope by any means. If you want to get rid of them, there are plenty of deer hunters who will use it at 100 yards and never go beyond that. The MOA is usually imprinted on the windage dial, it will have a little fraction or a decimal there telling what it is at 100 yards. There are a couple good scopes out there, Nikon and Pentax are decent. Leupold is about the best. It will deliver beyond your eye vision and rifles potential. I have a Bushnell on my M-40, mainly because I can't afford a $1000 scope, but I can shoot door knobs off at 200 yards all day. The scope is a piece of junk, but I have it set up right and it works, Hope this helps.
Apr 12, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I used all of the elevation adjustment on 3-9-50mm scope and my 22 rifle still shoots low at 25 yards
its a bad mount thats doing this,,,you can get over it easly by letting off the rear top mount of the scope (the mount near your eye) and pushing under your scope a strip of 35mm film this will lift the eye end of the scope giving you more range,,(elevation) only put 2 or 3 strips of film under the scope any more that this could bend the scope tube when you tighten it up
but a strip of film is about 25th of an inch and 1th will give you 1/4 of an inch at 100 yds ie:1 click! so you should easly get 10 inches at 100 yds or more with 3 strips of 35mm film under the scope even with bullet drop, the only other way to sort this out is to buy an adjusterbal mount witch is very pricy and 35mm film is cheaper, i do this all the time with my scopes
Nov 21, 2009 | Tasco Scope Guide Quickly Zeroing Rifle...
Will my scope remain zeroed at different distances?
You need to look at your bullet ballistics, Most guns should shoot dead on at say 15 - 17 yards out, to be on center at 100. Line of sight is straight the bullet must go over the line of sight to come back down and cross again so far out -- make sense? So no you will be a little high at 100 but may be close at 130 - 150. Ck on line for your ballistics with the bullet manufacture.
Jun 26, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Tasco Riflescope 3-9x50 Dwc39x50n Logo
223 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
