Changed the thermocouple and the waterheater starts up but shuts off a few seconds after
Iam guessing it is a fairly new hot water heater, when you put in the thermocoupler there should be some sensors there close by look for any carbon build up on them and any were else. if you know were the sensors are at just clean them off if you dont know were there at just do a good cleaning looking for carbon build up uninstall thermocoupler and reinstall and try again. if still not working check correct thermocoupler.
Posted on Aug 26, 2010
Pilot wont light
Pilot won't light ...
If we are talking about an OLD TIME "open flame"
PILOT...
There is a lighting sequence... Push & hold the button
put a MATCH to the gas and count to 30 (thirty seconds)...
Will USUALLY get the job done...
The HOLDING for 30 seconds... ALLOWS
time for the THERMOCOUPLE to warm...
assuring the flame is active and RAW GAS is
not escaping (important safety feature)...
MOST common cure for FAILURE to stay lit: REPLACE
that THERMOCOUPLE...
Still carried by most hardware stores... it is important
not to OVER-TIGHTEN the new replacement...
Ideally... you should MEASURE THE LENGHT and
make sure you are buying the right length/size...
Amazon example
Honeywell CQ100A1013 24 Inch Replacement Thermocouple for Gas Furnaces...
eBay example
Universal Thermocouple 24 works with Most Gas Furnaces water heaters...
I buy two...
(I have a SPARE IGNITER or Thermocouple for
every oven, water-heater... heater and patio heater
that keeps my wife happy).
Carnac the Magnificent
Nov 18, 2017 | Heating & Cooling
If the pilot go out on a furnace would gas continue to flow to the pilot , or would it shut off with in a few seconds
The pilot flame heats a thermocouple, so if the pilot goes out, the thermocouple cools and shuts off the gas. It can take anywhere from 20 seconds to 2 minutes for it to shut off. You should hear an audible click when it happens.
Sep 14, 2014 | Heating & Cooling
My hot waterheater will light but when i release the reset button after over a minute the pilot light goes out. what do i do
There is a small probe with its tip in the pilot flame called a thermocouple,
this is a flame failure device and shuts off the pilot in the event the flame goes out due to wind water or no gas, this device can become bunrt out usually after many years of use and can normally be replaced, you can purchase a universal thermocouple from most gas appliance retailers
Mar 06, 2011 | Whirlpool Water Heaters
How to change bad thermocouple on reliance gas hot waterheater reliance 606
it is important to turn off
the gas supply to the water heater at the manual gas shut-off
valve. This valve is typically located beside the water heater.
Note the position of the shut-off valve in the open/on position
then proceed to turn it off.
2. On the lower front of the water heater locate the combination
gas control valve/thermostat. Depress and hold
the lock tab located under the gas control knob on the right.
Rotate the gas control knob on the combination gas control
valve/thermostat clockwise until "OFF" aligns with the mark on
the front of the gas valve. Once the gas supply has been shutoff,
remove outer door. 3. Using a 1/4" nut driver or socket loosen the two screws securing
the manifold door assembly until they are free. Do not
totally remove the screws and plastic retainer washers from
the manifold door. The screws and retainer washers will be
needed to reattach the manifold door. 4. In this step, the thermocouple, manifold tube, pilot tube and
igniter wire will be disconnected from the combination gas
control valve/thermostat. Using a 7/16" wrench
disconnect the thermocouple (left-hand thread) and pilot tube
(right-hand thread). Using a 3/4" wrench disconnect the manifold
tube (right-hand thread). Carefully pull the igniter wire from
the igniter button.
5. Grasp the manifold tube and push down slightly to free the
manifold tube, pilot tube, and thermocouple from the combination
gas control valve/thermostat. when installation is complete and gas is back on, You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Nov 27, 2010 | Reliance Natural Gas Water Heater Control
My bosh 2400E LP waterheater fails to ignite often and I have to reset it. At the moment it will not fire up at all. It has run sporatically but not consistantly in the two years it has been installed.
You may very well have a defective thermocoupler. It id the bulb that sits at the tip if the pilot flame. It neeeds th be changed out. Good Luck
Oct 15, 2009 | Water Heaters
Pilot light will not stay lit
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
Heater shutting off
this type of heater is very sensitive to the state of the pilot since it uses a Renni type thermocouple to sense a low oxygen situation. Usually the pilot needs to be cleaned. If that does not restore operation only other thing to do is try replacing the thermocouple.
A low pilot will usually hold for a few minutes so I would expect that you have a bad thermocouple.
Nov 17, 2008 | Desa International Blower Glow Warm Wall...
Heater goes off
Possibly A bad thermocoupler. It is the part that looks like a stiff solid copper wire with on end sticking in the flame of the pilot light and is a safety feature if the pilot goes out it starts to cool and the resistance changes back you the module and the module shuts the gas off. I have seen these go intermediately faulty in waterheaters and do just what you described.
Jan 08, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
