Question about Samsung WF316BAC 3.79 cu.ft High Efficiency Front Load Washer
When the machine is switched on,water starts leaking.
Good luck with your machine! Ours has the same problem, and the motherboard fried out twice, the seal broke once, the door lock broke , oh and the GFI switch samsung sent out to prevent an electrical short and fire hazard stopped working after 1 month of use; and we've replaced that GFI twice ourselves and Samsung won't do anything to help us or exchange this lemon machine
Posted on Sep 02, 2010
My machine seems to be stuck on a drain cycle
Sounds like your 'anti flood' system is activated. This happens when a leak fills the drip tray on the base of the machine, and a anti flood float switch senses water in the tray. Leaks can come from several sources - loose pipes, leaking door gaskets - even opening the door while the machine is hot! i.e. to add an extra item after the machine has started, for example. ISOLATE THE POWER and examine the base tray, if its a free standing machine tip the machine back at an angle (The Hemlich manoeuvre for Dishwashers lol) and the water will flood out - if built in, remove the lower front panel. Once the water is removed, the machine should start - but if the problem occurs, the leak is still there. Zanussi machines are tricky - you'll probably need an engineer to sort it out - expect not much change out of £100. Cheers!
Oct 16, 2015 | Zanussi 18 in. DCS12W Free-standing...
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
LDF6810ST/01 no water
The pump out motor starts because it detects some water leak and is a safety switch on a polystyrene float. Find the cause of the water leak (hose or hose clamp) dry the water and this should solve your problem
Apr 20, 2013 | LG LDF6810ST Stainless Steel Built-in...
WATER LEAKING FROM TOP WHEN START SPINNING,MY WASHER IS MAV 7600AWW,I CHANGED THE SEAL AND STIL LEAKING
Does this happen on any water level setting, or just on full load? If the machine is overfilling, the centrifugal force at the start of the spin cycle will throw the water up the sides high enough to overflow the top of the tub.
If the machine is overfilling just a little as I suggest, then the water level switch may be out of calibration or the water level hose may be partially clogged at the tub end. A quick fix in the latter case would be to disconnect the hose from the level switch and blow compressed air through it - it's a lot easier to get into the control panel than the side of the tub. A leaky hose would have a similar effect.
Feb 04, 2011 | Maytag MAV7600 Top Load Washer
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
My machine doesnot fill water,as water start's and fill my drum it start leaking from somewhere, we checked water leaks from water pump. Last year we replace water pump. ya we change drain hose also.that...
The valve to the powder drawer is jammed. When you try to start the machine it trys to open and he water will try to pass through the valve. The water is at a constant pressure when the machine is off, but when you turn it on, it increases the presure and the water leaks. To the back of the maching, look at the blue hose, to the back of the washer, that should be sound, take the top off the machhing, two small screws at the back, follow the black hose from the cold inlet to the valve and I think you will find that is split/perished. I hope this helps, but if not let me know and I'll check o/l to find the fault for you.
Jul 16, 2009 | Washing Machines
Whirpool LSQ9200LQ Top Load water leaking on start of pump out
Transmission may be bad. When machinbe goes into very start of spin it should drain the water first and then machine will actually spin; tub should not be spinning. If it is, water cyclones up sides and will come out at tub cover. Only fix is to repl trans or select lower water level if I am correct in the diagnosis.
Nov 30, 2008 | Whirlpool LSQ9600L Top Load Washer
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
Samsung WF316BAC 3.79 cu.ft High Efficiency Front Load Washer Logo
97 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
