Question about PfaFF Quilt & Craft Pro 7530
When using twin needles only one line of stitching is stitching normally, the other line is jumping stitches. I have tried rethreading & changed the twin needle. With the first twin needle the left hand line was the problem, with the change of needles it is now the right side. I have frequently used twin needles before without a problem.
    Problem Solver:
  • 6 Answers
Now that is strange. check your thread, now take that twin needle and try this, shove it very hard up into the the needle holder. my thought is that it is not up enough. because your problem is exactly what would happen should the twin needle be sitting too low. try shoving it up higher and test again.
Posted on Aug 26, 2010
I inserted the twin needle and threaded it. However, I don't know what what stitch I should use.
we have no idea here either try someplace that gives sewing classes locally
Feb 16, 2017 | Sewing Machines
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
My machine is skipping stitches i have dusted it, rethreaded it, changed the needle and still it skips
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 17, 2012 | Janome Memory Craft 9000 Computerized...
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Kenmore 1941 sewing machine irregular stitches
try rethreading the machine top & bobbin make sure to get ever thread guide
try chaning to needle, make sure the needle goes all the way into the needle holder-normally flat side goes to the back of the machine
check to make the thread is moving smoothly around the tension dial
if these suggestion don't help, then the machine probably could use a servicing
Mar 13, 2012 | Sewing Machines
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
Using twin needle with Janome dc3050
you can just use the straight stitch.If you want to use a fancy stitch you have to be careful that the throw, as I call it is not too wide as you could break the needles and put the timing out. Also use a longer stitch than normal.Also use the stretch twin needle.
Jan 30, 2010 | Janome Sewing Machines
Janome 1600P DB Stitch length
The machine is skipping stitches and is probably out of time. Change the needle, rethread the machine and try it again. If it still skips stitches, try lowering the needle by about 1/16 inch and see if it works better. If the timing is off you should take it to a technician for a complete service.
sewman7
Jul 14, 2008 | Janome Sewing Machines
Sewing Machines Logo
195 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
