The lamp on my Samsung HLP5085 burned out last night with a loud pop. I followed online instructions to remove it and orderd a new lamp. Then, I noticed that a small 1"x1" piece of glass between the lamp and color wheel is cracked. Can I buy a new piece? If I buy a new wheel does this little piece of glass come with that? Thanks
It's doubtful that buying a new color wheel will solve that cracked glass problem. However, if you are going to buy a new color wheel you may as well purchase a new television as they are extremely expensive and most new units do not use them. I suspect the piece of glass may be protecting the lamp from anything on the inside of the TV or preventing anything from getting to the color wheel so it may work out just fine the way it is. I would suggest reporting back after you have replaced the bulb. In other words, don't order anything else just yet.
Posted on May 06, 2008
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Loud pop
Check the lamp.
Pull it out and look at it.
More than likely the lamp has shattered inside the set and needs replaced.
Bulb replacement is made for consumers and can easily be replaced.
Need any more information, respond to this post and I will reply.
Dec 30, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Samsung 50 inch tv blew last night burning smell at time not getting any picture just a clicking sound
It sounds like either the lamp has blown or the ballast for the lamp has blown. You can call 1-800-samsung for nearest service center.
Feb 23, 2010 | Samsung DLP HL-P5663W 56" TV
No picture on my Samsung HL-R4667W TV.
Its your Lamp if you have sound and no picture.
CK the lamp Fan make sure it is running.
Lamps Prices depend on where you buy.$85.00 up to $300.00 Look on E-Bay under Electronics/ Lamp number-BP
Mats Electronics has them for $99.00
1-800-628-1118
remove your Lamp and look in middle of it,that will tell you if it is busted.
Feb 20, 2010 | Samsung HL-R4667W Rear Projection...
We heard a pop last night the screen went black but we can still hear and the tv turns off and on
Most likely the loud pop that you heard was the lamp filament shattering and you can verify that by physically inspecting it,the UHP lamps have a life expectancy of 6000 to 8000 lamp hours when they are Phillips and from 3500 to 4500 lamp hours if it is an Osram,and you can find this items on discount-merchant.com or on Ebay
Please rate this answer if it was heplfull
Feb 18, 2010 | Toshiba 53AX62 53 in. Rear Projection...
My Hitachi 70" LCD will not turn on
Take the door back off and look for a safety tab somewhere on the door that will activate a small safety switch, the tab will stick out. Maybe you broke the tab off or just didnt get the door on correctly. Try that and let me know.
Feb 04, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Loud pop and picture went out.I have sound but no picture.
I had this happen a few months ago. More than likely the color wheel died. I opened up the back of my Samsung DLP expecting to find a blown lamp, but came to find out that only the color wheel was in need of replacement.
Sep 26, 2008 | Samsung HLN5065W 50" Rear Projection...
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Mar 16, 2008 | BenQ MP610 Multimedia Projector
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
