Question about Kitchen Ranges
Dishlex 100 Dishwasher Upper and lower baskets rusting Is it worthwhile to replace ?
  • Kitchen Ranges Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Yes, that is not that hard to fix and you can easily buy the parts yourself online...<br /><br />Here is a tip that will help you with the online buying...<br /><br />How to Buy Appliance Parts Online<br /><a rel='nofollow' href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online" target="_blank">http://www.fixya.com/support/r3907570-buy_appliance_parts_online</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Posted on Aug 26, 2010
I need to buy a new cutlery basket for dishlex DX103 where can I get one
Might find a comparable one here.. http://www.ebay.co.uk/bhp/dishwasher-cutlery-basket
Jan 02, 2017 | Dishwashers
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
My dinner plate stops the arm rotating, why? model fdud4812
Both upper and lower washing arms operate on the water pressure and angle of water flowing thru them.
Pressure provided by water pump.
Just about anything that contacts the rotating arm can stop it.
Best thing to do is re-arrange items in dishwasher so that arms can spin freely.
One can always spin washing arms by hand to ensure proper clearance.
Hope this helps...
Jul 30, 2011 | Hotpoint Dishwashers
Kitchenaid dishwasher model kudm24se the upper and lower baskets have rusty areas. Would like to replace with new baskets or a method of correcting or fixing the rust spots
That is not that hard to replace and you can easily buy the parts yourselfonline...
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jun 02, 2011 | Dishwashers
My dishwasher lower basket has some rust. Is there paint or other solutions short of buying a new basket? Kitchenaid / kudm24sewh2
the paint dose not work well, If the wire is not in a super critical place, I sometimes cut them out and cap them with a rubber coated dishwasher repair kit that I purchase at my local appliance repair shop. You can probably order that on line, I found them here.. http://www.searspartsdirect.com/partsdirect/part-number/675679/0022/665?sid=SPDx20101116xGPROD
May 10, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
Garbage disposal mechanism cannot be disassembled for repairs.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Attach electric wire to new disposal.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Remove old sink basket and clean opening.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Require replacement of cultery holder for dishlex G450 dishwasher Located Northern Beaches, Sydney.
Part number 5303282018 runs about $20 in the U.S.
http://www.bizrate.com/dish-washers/frigidaire-dishwasher-silverware-basket/
Sep 27, 2009 | Frigidaire 24 in. FDB126RB Built-in...
How to repair rust on lower basket of dishwasher
Use sandpaper or brillo pad to remove rust, and paint it with acrylic appliance paint
Apr 15, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Problem with dishwasher detergent dispenser
we should replace the whole dispenser otherwise it can be leaked
Mar 23, 2008 | Dishwashers
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
