Question about Whirlpool LEB6300 Electric Dryer
I have a broken belt, how do you replace it - Whirlpool LEB6300 Electric Dryer
    Novelist:
    Champion:
  • 266 Answers
First take the two screws that are exsposed after you remove the lint trap. Next use a flat bade screw driver and insert it in the seam between the front and top approximately 2 inches in from the side. There is a spring clip 2 inches in on each side you have to trip by shoving the screwdriver in about 1 1/4 inches. The easiest way is to tap them with a hammer. (pry upward on the top and lift it all the way up it will be hinged on the back. Now looking down each front corner you will see a 5/16 screw approximately 8 inches down from the top. Remove these screws and the front can be tilted outward and lifted straight up. You will see a door switch and wires attached to the front remove the wires. Set the front aside and out of your way. (if you are a very flexable person you can replace the belt from the front but us normal human beings have to remove the back) Next go to the back and remove the back panel there are several 5/16 hex head screws around the outside edge of the back panel remove them and set the back panel aside. Inside on the bottom left side as you face the back of the dryer you will see a motor and a tensioner. The tensioner may still be in place it goes in a slot in the bottom of the dryer next to the pulley on the motor. Remove the old belt it usually is laying in the bottom. Put the new belt on the drum by putting it around the drum from the front. The belt goes around the drum across the pully on the motor with the tensioner and its pully putting tension of the belt to take up any slack. Then just put everything back in reverse order. Make sure the tensioner pully rotates smoothly if it does not this can cause your belt to break or usually get thrown off the pully. Remember to unplug your dryer before starting and clean the excess lint out of the bottom of the dryer as a good prevention to other problems. I hope this helps and good luck
Posted on Aug 26, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Broken belt
    Please check on this link for tips to replace the belt
    click on belt replacement
    Jan 15, 2013 | Amana Washing Machines
    Broken belt dyson Dc41
    Belt was broken, so I had to go inside the motor assembly -- torx screws all the way. The problem is finding a replacement belt without buying a whole new power drive.
    May 03, 2012 | Vacuums
    Does the timeing belt have to be on for the crank to turn the cam when instilling the timeing belt?
    Are you replacing a broken timing belt? Or are you replacing a belt because it's due by miles? If the belt is broken, i strongly suggest inspecting for bent valves. Daewoo is notorious for bending all valves and breaking valve guides in the cylinder head when the timing belt breaks. The broken belt is also common.
    Aug 05, 2011 | 2000 Daewoo Nubira
    Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
    broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
    The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
    Jul 08, 2011 | Kenmore 63932 Electric Dryer
    Ac belt broken. Is car safe to drive? How hard is this belt to replace?
    as long as the water pump, alternator, are working properly. but if it has just one serpintine belt that drives all things it must be replaced. before running. if only the ac belt, it is ok to drive if it has its own belt that is broken.
    Aug 13, 2010 | 1995 Isuzu Rodeo
    Fan belt replacement
    Pop the top - it is held in place by spring clips. Lift it up ... you should see the belt. If you can lift the belt, it is broken - if you don't see it, it is broken. If you see it and can't move it, you have a different problem.
    Broken belt, remove the front panel - be careful of the door wires.
    The drum will fall free - remove it. Pay attention to the belt tensioner. It snaps into the floor. The belt goes through the tensioner and around the motor pulley.
    Get a replacement at a appliance parts place or from a FixYa.com advertiser.
    Thanks for your interest in FixYa.com
    Jan 09, 2010 | Dryers
    Beater? bar doesn't spin
    That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
    Replacement Vacuum Belts
    Dec 08, 2009 | Vacuums
    Replace a broken belt
    Here is a link to the owners manual which has instructions and a link to the belt you need.
    Eureka Altima Owner's Guide
    Eureka Altima Replacement Belts
    Nov 15, 2009 | Vacuums
    Whirlpool LEB6300 Electric Dryer Logo
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
