Question about Acer AL1714 17" LCD Monitor
Acer lcd screen power button broke - Acer AL1714 17" LCD Monitor
  • 11,361 Answers
Can you feel that it click when you push on it? It is a momentary type tactile switch that you can get from <a rel='nofollow' href="http://www.mouser.com">www.mouser.com</a> that you need to match the size and dimensions.<br /> You may have problem some where else.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a rel='nofollow' href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Posted on Aug 26, 2010
Acer 4552 dead screen
hi,
check lcd cable
replaced lcd panel
Apr 06, 2014 | Acer Aspire 4552 Series Laptop Power AC...
Replaced dc card now powerbutton has yellow indicator
Blue screen errors are normally hardware based. Remove the power source and battery. Remove the RAM and Hdd. Power it up and see what the error message is on your screen.
Mar 12, 2014 | Acer Aspire 5500 5570-2609 Laptop
Black lcd screen
try to connect it to an external monitor to see if video card is working.
if yes, the the internal card/lcd screen connector may have become loose or your screen is broke.
you will have to remove some parts to check this.
before doing so, get the manual(paper or download) first and look where all the little screws are. if you know someone who can repair PC's he might help out if you let him...
it is a fiddly work but seeing a technician may be cost-intensive.
PLease decide yourself...
Aug 04, 2009 | Acer Aspire 3680 Laptop
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Screen keeps going off and on
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Feb 21, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 5100 new screen and still goes blank.
Jan 25, 2009 | Acer Aspire 5100 Notebook
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Black screen
check display on the monitor through the vga port of the laptop, if there is display then its the porblme of your screen
Jul 28, 2008 | Acer Aspire 5610 Notebook
Vertical positioning setting is frozen
lets see what i can do
sometimes under the screen edge either side or bottom they have the menu buttons these have become hard to find but there on your screen on one of the buttons the select should be de gaus (spell check) this sends a powerful power signal to monitor to reset its self some times its scary to watch but when it does that it should release the buttons parameters back to working state then use the buttons to set your parameters
the other thing is there is something stuck or broke in the button which was pushed a little harder then most
if this is the case
and you dont want to mess with monitor then take to computer tech. they will tear down and replace button backing sometimes the button backing points break off or disalign do to tomuch preasure on the button
i hope this helped you
May 25, 2008 | Acer AL1715 17" LCD Monitor
Suddenly a black screen!
If your good with computer or know some one that is, sugggest you to remove the LCD rim, and clean the ribbon filament that is connected to the monitor. Sometimes this filament get's dirty and just need to be clean from a cotton swab.
Another solution is for you to plug in a monitor to the laptop.
May 06, 2008 | Acer TravelMate 2300 Notebook
Open Questions:
See all Acer AL1714 17" LCD Monitor Questions
Acer AL1714 17" LCD Monitor Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
