Question about Bosch Dishwashers
The bosch turns on but does not fill with water and makes a humming noise.
  • Bosch Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you to find out why water will not come into the dishwasher... <a rel='nofollow' href="http://www.fixya.com/support/t4715125-when_water_filling_or_rinsing" target="_blank"></a><br />Dishwasher Trouble No Water entering Dishwasher <a rel='nofollow' href="http://www.fixya.com/support/t4741705-no_h2o_fill" target="_blank"></a><br /><a rel='nofollow' href="http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering" target="_blank">http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Posted on Aug 26, 2010
4 Suggested Answers
  • 190 Answers
SOURCE: Broken Dishwasher : Bosch SGS53A12GB/01
dear customer,
For such cases we recommend you to follow the below stated routines..
  • Unjam the motor
  • Unjam the pump
  • Test the motor
  • Test the motor start relay
  • Check the drive belt
  • This usually solves the problem. hope u find this useful.
    Posted on Jul 09, 2008
    mastatech
    • 478 Answers
    SOURCE: Bosch SHV46C
    Replace the fill valve that sound is it trying to open
    Posted on Mar 12, 2009
    here2helpBSH
    • 27 Answers
    SOURCE: Loud humming noise when dishwasher is filling up with water
    your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
    there are two components that start before the circulation pump.(wash noise you hear)
    first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
    the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
    Posted on Mar 19, 2009
    A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
    Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
    Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
    Makes humming noise and does not fill with water
    Here is a tip that will help you to find out why water will not come into thedishwasher...
    heatman101
    Mar 21, 2011 | Bosch 24 in. SHX46B05 Stainless Steel...
    Moved to new home hooked everything up washer will not fill
    ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
    Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
    Kenmore washing machine fills with water then stops
    turn the motor to see if it moves it sound like the motor
    May 02, 2009 | Kenmore 24032\24036 Top Load Washer
    Bosch dishwasher timer sticking
    I have been told to replace the timer which I am looking to do the same to my machine!
    Mar 24, 2009 | Bosch Dishwashers
    Bosch SHV46C
    Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
    Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
    Washer makes noise, will not fill
    turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
    Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
    dear customer,
  • Unjam the motor
  • Unjam the pump
  • Test the motor
    Jul 09, 2008 | Bosch Dishwashers
    Bought the display unit and water will not work.
    hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
    Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
    Dishwashers Logo
    168 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
