Question about Brother MFC 210C All-In-One InkJet Printer
Just want to copy - ink is low or out - I don't care
Want to copy. won't let me because low or out of ink. I don't use it to print.
  • 81 Answers
You will still need to replace the ink cartridges if you want to copy, as it will still use ink.
Posted on May 14, 2008
Ink is low epson me10
if your ink is low, you need to buy more ink. OR you can buy ink refill kits ( super cheap ) just be careful filling the ink cartridges so you don't over fill.
If you have only printed a few things ( photo's aside) and are low on ink, then try NOT printing the best quality. adjust the ink quality settings in the properties when your about to print.
Note: if your just printing text and it's not for anything super important ALWAYS go with draft. it prints faster and uses a lot less ink.
Jan 01, 2014 | Office Equipment & Supplies
Dell printer won't print
It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
Jun 03, 2017 | Dell AllinOne Multifunctional (v515w)...
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
Why Canon MX310 won't scan error 114.0. how to fix
I have this copier too but only use it as a copier in my classroom. It's a stand alone. But can't print. There is no software to install on a computer so I don't know how to fix it if there's no software.
Feb 26, 2012 | Canon PIXMA MX310 All-In-One Printer
I bought the wrong printer for my needs and the cartridges for my HP Photosmart C309g-m run out when I don't even want color. Is there a way to set permanately, not with every printing secssion to use...
Hi
Yes you can set it to print permanently. You have to go to Printer proprieties and go to color option and choose Gray scale printing only and this will not use the other inks at all but black cartridge only for printing.
Jul 27, 2011 | Office Equipment & Supplies
WE HAVE A KODAK ESP-3 AND HAVE PUT IN NEW INK (BLACK) AND IT WON'T PRINT. THE COLOR SHOWS EMPTY BUT IT'S ALSO NEW. ONLY WANT TO PRINT BLACK BUT IT WON'T PRINT EITHER JUST SHOWS LOW INK ETC.
First: you need both ink cartridges for the printer to function properly.
Second: You may have a bad printhead, do the following:
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Contact Kodak:
All-in-One Printer Phone Support Live telephone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight, Eastern Time, 7 days a week. The expected wait time for phone support is 15 minutes.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 27, 2011 | Office Equipment & Supplies
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
2. Open the scanner.
3. Open the cartridge cover.
4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
7. Remove the yellow tape from the bottom of the cartridge.
CAUTION:
Do not remove any other labels or seals, or ink will leak.
8. Insert the new cartridge into the holder and push it down until it clicks into place.
9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
10. Close the scanner.
11. Press OK to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
Won't print faxes
What printer are you using?
Mar 05, 2008 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
