Everytime I turn on the television everything works fine except no sound. Sometimes unplugging the set and plugging it back in a few moments later fixes it. Sometimes redoing the 10 minutes long auto channel scan works too. But it happens everytime. Also, it isn't exclusive to the cable. If the sound doesn't work with my cable it also doesn't work with the DVD player. So no sound PERIOD. Thanks a lot for your help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
It signifies that there is a problem in the audio circuit on the PCB BOARD TV, you should check starting from the section "Audio Amplifier" check incoming voice signals on the L or R-in Audio-in Audio that led to the AUDIO IC amplifier. If you hear a sound when touched (touch point of tin solder to use a screwdriver) audio input pin means in part that there is no problem, you proceed to check into the IC close to the tuner (it is usually called Chroma IC / VIDEO + combination of Horizontal Drive + Vertical Drvie + IF). Just look at the physical form of IC is greater than the other ICs. tin solder first check whether there are loose or melting resulting in less good solder connections on each foot of the IC. It enables voice sometimes appear and sometimes not. if, after checked and looked normal / still good, you must replace the IC. I did not explain exactly NO. CODE from the IC because you do not describe the specific model and brand of your Flat TV.
Posted on Aug 26, 2010
I plugged in a computer and changed the input to VGA and the TV went blank
It sounds like your tv is in sleep mode.
What are the settings for the computer? Make sure it is set for the vga output. If it is a laptop, this is usually done with a function (FN) key. On your settings screen you can set the resolution and which monitor you are using.
Sep 29, 2012 | Polaroid 2611-TLXB TV
I have a DYNEX LCD37 for 2 years, it was working great untill I plugged in a new HDMI cable to use my laptop, after a few uses I turned my tv on one day and the Contrast was lost, everything works fine...
The tv Tuner signal board have problems,might need the replacement of the Tuner signal board it self.Tries the tv unplug,replug it back in like an hour later.Let the tv resetting itself back to the factory setting.See,if that solved ur problems.Not,than the Tuner signal board have problems itself,must be replaced the Tuner signal board itself.
Oct 26, 2010 | Dynex DX-LCD37 TV
Philips 55PW9363 hd tv has sound but no picture. Was working fine before it was turned off and this happen when it was turned on about an hour later.
You may have a bad, small signal board. Once in a while you may get a picture back....if the TV has been unplugged and plugged in after a few days.
Jan 30, 2010 | Philips 55PW9363 55" Rear Projection...
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
Everytime i turn off the tv and turn it back on
Tries unplug,replug 1 hour later,tv should reset itself to factory setting.
Nov 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
Weak audio gets weaker
The ocean sound is 'noise' which means a bad connection. Best thing is to unplug & plug back in all cinch & scart etc cables, while turned off, of course. do this a few times for each cable, then turn it on.
Sometimes it is the headphone jack, have you used it recently?
Try plugging & unplugging the headphones quickly a few times, that normally solves the problem.
If you still have a problem then it's internal and the TV needs looking at.
Apr 22, 2017 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
