Question about Malber WD1000 Front Load Washer/Dryer
Does not get in water not spining - Malber WD1000 Front Load Washer/Dryer
  • Malber Master
  • 43,501 Answers
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"> </span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"> </span><br /><span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt; mso-ansi-language: EN-US; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><br />Washing Machine Problems No Water<br /><a rel='nofollow' href="http://www.fixya.com/support/r3880845-washing_machine_problems_no_water" target="_blank">http://www.fixya.com/support/r3880845-washing_machine_problems_no_water</a><br /><br />Washing Machine Fix Washing Machine No Water<br /><a rel='nofollow' href="http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no" target="_blank">http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span>
Posted on Aug 26, 2010
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Haier washing machine taking water in and taking water out but not spining it gave burning smell once after that stopped spining
From the limited information you provided, I would concentrate on the transmission. Most are a two speed transmission - low for wash cycle and high for spin. If it isn't doing either, you should make sure that it is getting a signal to the transmission from the control board.
Jun 23, 2011 | Washing Machines
Wasing mechine does not stop spining after draining water &keeps spining ,does not stop automatically untill i stop manually eitherby opening the lid or pulling the knob
You need to replace the timer switch on your machine. If you will post your Maytag model number I can direct you to the part you will need.
Happy Holidays
Dec 13, 2010 | Maytag Washing Machines
Not spining and water not draining
Access the water pump and look for plugged drain hoses or a plugged filter as well as a slipping impeller on the pump shaft--or even a dead pump motor. Spin usually will not occur if there is a high water level in the machine. Try draining the tub into a bucket, then see if it will go into spin mode. Hope this helps!
Jun 27, 2010 | LG WM2277H Front Load Washer
Studs on the waterpump are free spining...
those a pressed in the sheet metal cover.. you can try to put pressure on the water pump pry it away slightly and then use a air rachet if you have one available.. that should work for you ..
Feb 19, 2009 | 1985 Cadillac Fleetwood
Washer not spining
i think there is problem in your water outlet pump problem first of all you check water is come out or not from machine
Feb 11, 2008 | GE Profile Prodigy WPSE4200A
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
