Question about Whirlpool LEB6300 Electric Dryer
When I push the "on" button, I hear a single click and it doesn't start
  • Whirlpool Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />There can be many reasons why your dryer will not start or<span style="mso-spacerun: yes"> </span>turn...</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />The most common causes are the belt breaking or jumping off, or the motor going bad...<br /><br />Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...<br /><br />Dryer Repair - The Dryer is not Turning<br /><a rel='nofollow' href="http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning" target="_blank">http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning</a><br /><br />Dryer Repair ? The dryer will not start<br /><a rel='nofollow' href="http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start" target="_blank">http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start</a><br /><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span>
Posted on Aug 26, 2010
All lihts ar on but buton to start not respond
When you push start button, do you hear a rapid series of clicks, or a single click?
Jan 30, 2014 | Harley Davidson FLSTC Heritage Softail...
Volvoxc70 doesn't start when i push in the button and then apply the break, after a few times it makes a clicking noise and then the noise stops. still doesn't start. am i actually trying to s
insert the key into the slot then step on the brake and keep it depressed, then push the start button. when it starts to crank release the button.
Feb 24, 2013 | 2004 Volvo XC70
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
Acer extensa 4420 shuts down right after you push power button
sounds like it doesn't have enough power, is it completely charged? you may want to make sure you're getting power from the charger itself.
Jul 02, 2012 | Acer Computers & Internet
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
My 97 HD sportster will not turn over
Uhh, is the battery good? Take it out and take it to an auto parts store. Ask them to test it for you. Usually, there's no charge for this. Make sure all battery connections are clean and tight. If the battery is good, the next step is the starter relay. When you push the handlebar button, you should hear a faint click behind the oil tank. The starter relay cost about $15 and simply plugs into a connector. On most models it's held onto the backside of the oil tank by a single screw. If you've got at test light, put the probe into the socket of the starter where the single small green wire plugs in. When you press the start button the light should light up. If not, either the relay is bad or the push button on the handlebar control. If you're getting voltage to the starter at the green wire, bad starter.
Sep 18, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Atv wont start when electric start button is pushed
Iguess she hosed the machine down ,water may have tracked and drained the battery ,and what you are hearing is the solenoid clicking....try another battery or jumper leads off the car you may be surprised .WHAT EVER YOU DO DONT,I SAID DONT.,RUN THE ENGINE WITH OUT THE BATTERY HOOKED OR YOU WILL BURN THE RECTIFIER OUT!!! AND IT WILL BE UNABLE TO CHARGE THE BATTERY, if the new battery doesn`t do the trick , you are going to haveto follow the clicking by ear until you find where the clicks are coming from let me know PLEASE I also can learn from your experience
Aug 28, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Start button not working.
probably your button is dirty had carbon inside. do you hear a click sound when press it? if so , the IC did not received the signal, it need to be check by a technician.
Jun 30, 2009 | GE Profile JT910SASS Electric Single Oven
1990 1200xl sport not starting
Is the clicking noise coming from the starter? If it is I would say your bendix is shot and needs to be rebuilt.
Apr 28, 2009 | Harley Davidson XL 1200 S Sportster Sport...
Whirlpool LEB6300 Electric Dryer Logo
16 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
