I have a maytag washer that needs a new lid switch. I was quoted $250 to repair...seems outrageous!!
    Genius:
  • 1,073 Answers
What is the model number and i can get you a part price sound high
Posted on May 06, 2008
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Can't get the water in the tub & it doesn't spin.
TRY THE LITTLE SWITCH THAT ENGAGES WHEN U SHUT THE LID... MY GE WASHER JUST HAD THE SAME PROBLEM ABOUT A MONTH AGO
Mar 14, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Neptune FAV6800AW Top Load Washer Code reads "OP" what does this mean?
Go here Neptune TL Washer FAV6800AWW
read the 7th post down ""issues related to the Left Hand Lid Lock for FAV6800A or FAV9800A machines.""
Mar 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag lat9593abw does not agitate
The lid switch, which prevents the washer from agitating or spinning when the lid is open, could be malfunctioning. If that happens, a built-in failure detector will stop washer operations until the lid switch is repaired. Replace with this part. Here is a video to walk you thru the repair.
Dec 05, 2010 | Maytag Washing Machines
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer won't turn on, I checked circuit breaker and plug. Model # MAV4758AWW
Below is information provided by www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams.
You may also find this to be of assistance;
http://maytag.custhelp.com/app/answers/list
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jul 17, 2009 | Maytag Washing Machines
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader MAV 8000MWW
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Sep 27, 2008 | Maytag Atlantis MAV8000
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
