Question about Mitsubishi LT37131 37 in. HDTV LCD Television
My LT-37131 was damagd by lightening which came in through the Phone/Coax and destroyed the CISCO set top box attached to the TV via HDMI interface. The TV works only on composite and component connections now. The HDMI (2), the DVI (1), Firewire (2), and COAX (2) ports are not working now. A local repair tech says the DM (Digital Media?) board is dead. They want over $600 to replace the board. Is it worth it for a 4 year old LCD TV?
  • 2,318 Answers
Hi ydoomgm901,
All the inputs mentioned that don't work are located in the main board and the inputs working are connected on a different board, since they might not been not in use at the time of the lightening.
The main board is the one that should be replace to get the defective inputs to work.
If this is something you might want to try fixing yourself, check this link to find the main. That could be a cheaper solution in case you decide to fix your LCD.
Let me know if you require further assistance.
Posted on Aug 26, 2010
I have a hdmi rca tv, unhooked the digital cable box for awhile went to hook it back up and can't get any channels scanning picks up nothing what should I have the setting set to? Hdmi set to cable
If you have a cable box the channels are selected via the cable box remote and the TV is set to an HDMI video input. The specific input is identified where the HDMI cable connects from the box.
Use the video input remote to select the HDMI for the cable box.
Scanning is for identifing the over the air stations that use the coax input noted as antenna (ANT IN) on the back of the set.
Hope this helps?
Mar 13, 2016 | RCA Televison & Video
I have a sanyo dvd player/video cassette recorder manufactured June 2003. what do I need to be able to record tv to vcr on my flat screen HDMI tv
Wall outlet <--- coax cable --> 1-to-2-splitter <-- coax cable --> Personal Digital Video Recorder <-- HDMI cable --> TV
and:
1-to-2-splitter <-- coax cable --> VCR
May 21, 2014 | Sanyo DVW-6100 DVD Player/VCR
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
I m unable to watch live tv on my cell phone nokia c2-01 3g
I believe you did not follow the right setting that was why you were unable to watch live television on your phone please follow the setting given below and you will be to watch the live tv on your phone.
The Hauppauge Digital Broadway Box can be a small stand on your own gadget that connects to any Television signal and streams live Television wirelessly to your cell system.
Television signals could be connected to the box via: cable Television, satellite set top box, antenna or TV coax cable. Once the Television source is attached connect the box in your Wi-Fi network and then open a browser on your device to begin viewing from http://distan.tv
Regards
Jul 08, 2011 | Lands Phones
I want to connect a vcr to the tv but there are no connections except one coaxial connection. The tv is also conneted to a DTV box. Any suggestions?
Without you giving any more detail about the TV or the set-top box, the box probably has the connections you need to connect your VCR. You could connect the VCR to the secondary coax on the DTV box, or if it has them you could use standard A/V connectors (yellow=video red and white=stereo audio).
The easiest would be to use the other coax connection and look in the DTV boxes manual to see if there is anything you have to change on the box via the menu system.
Thanks for using Fix Ya and happy viewing.
Mikeywaf
Mar 14, 2011 | Televison & Video
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
Can you tell me what are the functions of the two hdmi inputs, and the one hdmi output ,as my cable only works via the tv to the dvd player and a coax from dvd to the coax on avr, so hdmi on avr is...
Let's treat this as TWO functions - audio and video.
Your best video would be HDMI output (audio & video) from the cable box and EACH other video source (BD/DVD) directly to your TV and receiver. But, I'd still WATCH the video from the direct TV connection. The fewer intervening cables and electronics, the better.
Your best audio performance will come directly from each multichannel source via a digital (HDMI, coaxial or optical) cable to the receiver. I would LISTEN to audio through the receiver for best quality.
See a trend here? TV's best at video; receiver is the master of audio.
And neither one adds much by handling the other. Usually the opposite.
You mention coax. Do you mean coaxial digital audio????? As coax is also shorthand for the thick black cable bringing video to most cable boxes, connecting antennae to TV's and such.
You don't actually define what the problem is. Only YOU can be the judge of what 'better' is.
There are a multitude of (mis)settings you should master before declaring a hardware problem. I'd dive into the manual.
Aug 03, 2010 | Denon AVR-1508 Receiver
Audio on some TV channels/shows goes off. It varies by channel, sometimes national feed is silent, but local break-ins have sound. I have to set the Audio from A.F.D. to Movie to get audio. Sometimes I...
Not sure what this means: "The audio comes to the Cable box through coax cable." From where does audio come TO the cable box? The cable box is a source of both audio and video. Perhaps you mean the TV broadcast "containing the audio and video" comes in on coax.
Has this ever worked correctly? <<<<<<<<<<<<<<<<<<<<<<<<
Try this: disconnect the HDMI that goes from the cable box to the Video 2 on the receiver. Leave the optical audio cable in. How's the audio now?
Then try the reverse: reconnect the HDMI and disconnect the optical audio. You shouldn't need BOTH for audio into the receiver.
Now what happens?
Feb 17, 2010 | Sony STR-DG510 Receiver
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Mitsubishi LT37131 37 in. HDTV LCD Television Logo
122 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
