Question about D-Link Televison & Video
I have purchased a secondhand 26" DL D2619 LCD television with no remote or Manual ( Stupid me) When I turn the power on the screen says NO SYNC what does this mean and how do I get a picture???? please HELP
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
SOURCE: LCD Screen is blank
I removed the battery for 60 minutes and then re-inserted it while holding down the "OFF" button as was posted before - THAT made all the difference.  I got the "safety message" and then updated the remote and all is well again!  I didn't wait long enough with the battery removed before...
Posted on Feb 17, 2009
  • 4 Answers
SOURCE: removal of television lock on sinotec television
Try Holding Down The music button for about 10 seconds. Worked for me.
Posted on Jun 16, 2009
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
Remote issues with shaw cable box - volume, channel selection and power - how to sync the remote with the tv and/or shaw box/remote?
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Jan 29, 2013 | Acer AL2671W 26 in. LCD Television
How to get past the language screen
Usually with the remote enter the "menu" to see what options you have.
If all you get is the display screen when you turn it on--it may be locked there---
If you recently had a power outage or unplugged set while it was on--unplug set for a while and try again.
This is a general answer as description is a little vague.
Mar 31, 2012 | Protron PLTV-26 26 in. HD-Ready LCD...
TV will not turn on.
Using an aftermarket remote (DirectTV, purchased from EMTC) I was able to get it turned on using a code referenced by the instructions that came with it. If you look in the TV's manual it refers to using the SET button when trying to activate the correct code setting for the TV. This button is not present on this remote. However, reading elsewhere in the manual, and the remote's instructions, I concluded that (for this remote) simultaneously pressing SELECT and MUTE was equivalent to SET. I used that and one of the suggested codes and the set turned on!
Dec 07, 2009 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Missing instruction manual
Here is a link to the television manual with detailed remote control instructions starting on page 20 for that model remote control. http://www.abt.com/images/products/PDF_Files/26AV502U_manual.pdf
Sep 26, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
Where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Feb 06, 2009 | Niko OTP-2613W 26 in. LCD Television
Getting full sceen picture
Try the "picture size" button on the remote.
Sep 15, 2008 | Sansui HDLCD-2600 26 in. LCD Television
1/3 of screen loses sync
It sounds like you have a bad Inverter. we need to run TV in SAM and check for errors. Contact me.
Mar 16, 2008 | Philips 26PF9966 26 in. LCD Television
No signal on screen
first of all do you see anything on screen if you press menu.if you do then wate for menu to go away then press source button on top or remote should see in one corner vid 1,2,ext ext if you don't see anything on screen this chinesse tv is not working (WHAT A SUPRIZE) you need to see some graphic's on screen tosee if backlight is working or your in the same boat as everybody else that owns one of these tvs no fix no help from company. GOOD LUCK DOC
Mar 06, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Mintek 26" lcd hdtv dtv 265-d
mintek dtv-265-d THE TV WILL ONLY PLAY CHANNDEL 34 THE REMOTE WILL ONLY TURN ON OR OFF IS THERE A SERVICE MANUAL OR A REPAIR!!!!!!!!!!!!!! rad
Oct 09, 2007 | Mintek DTV-263 26 in. LCD Television
Televison & Video Logo
67 people viewed this question
Top D-Link Televison & Video Experts
David Payne
David Payne
Are you a D-Link Televison and Video Expert? Answer questions, earn points and help others
